I am having a problem with the start up on my 2012 sierra 6.2L. at startup it high idles for about 2 seconds then drops and stumbles then it catches itself before stalling then smooths out. It has stalled out once. This only happens on the first start up, if i start it up again after this happens it starts normally.
When i park my truck outside overnight it is not as bad as the truck high idles for a bit longer due to the cold temps. The times it happens where it is the most noticible is when i drive home in the morning after night shift when it is cold outside then i park in the heated garage, Then when i start it in the afternoon when the temps are warmer that is when it happens. My tahoe with the 5.3L never has this problem, and the tahoe is parked in the garage all the time.
I have been using a scan tool to try and see what is happening at start up and one thing i notice is when the ambient air temp sensor is reading a lot lower than the intake temp sensor the more noticeable the problem is. I am pretty sure that the ambient air temp sensor has nothing to do with start up but it is something that i seen, the DIC temp shows what the temp actually is. when i started it today coolant temp sensor, and intake temp sensor both read 24 celcius as did the dic was showing 24 but the scantool was showing the ambient temp at 6, i started the truck and it did its stumble then he ambient temp jumped up to 24 as the truck smoothed out.
With tuning my car i know that ambient temp is only used for the climate control but this is the only thing i see different The truck is stock right now i just want to get everything running right before i start tuning it.
Is there something that could be causing this, or something i should be logging during startup? the truck runs fine with no codesSorry for the long post but there seems to be a few people with this problem but no answer.
Sorry for the long post but i am hoping that someone here will be able to point me in the right direction
