Results 1 to 3 of 3
Thread: Silverado 2014
    Feb 2015
    12
    Silverado 2014
    My greetings to all, I am new in this field and would like some help. I'm working with a 2014 Silverado OEM, and I've made some improvements, but I can not resize the tires having a size higher than the OEM
    Tuning Addict
    Jan 2015
    6,802
    Should be under speedo - calibration - tire revs per mile if it's got it. Otherwise might need to contact support, because I know they're supposed to be in the ecm. Also make sure your setup as Advanced under your edit tab.
    ~Greg Huggins~
    Feb 2015
    12
    ok, i found what you told me to in the program, now i want to know what should be the calibration if the size of the tire is 215/55 R20? as i am not sure how to do the conversion to modify the original size of the tires.
