Have a swap here with an 07 E38 PCM, vette pedals, CTS-V TB, and a T42 with a 4L80E. Which trans segment/from which vehicle can be used in conjunction with the Vette OS to run everything? Or can a full truck OS work with the Vette pedals?
What year V did the pedal come from?
http://www.dsxtuning.com
Just say no to bull s***.
The Pedal is from an 04 or 06 vette
the TB is unknown exactly what year CTS V but it uses same connector as 08 escalade.
Haven't used the segment swapper in 2.25 yet, do you have to license both donor files?
Post a pic of the throttle body.
If you don't need BCM functionality, use 07 Corvette in the ECM and 08 Chevy Express in the TCM. Segment swapper won't let you do that though. You will have to download a file from the repository, write entire just the TCM for the 4L80, then write entire just the ECM with the Corvette file (unless it's already loaded).
