There's not really enough data there to tell much honestly. It takes a good 30 minutes IMO for things to settle down after you flash it
Also, add throttle position to what you're logging
edit: yeah I just noticed this was just an idle'ish log, so that makes more sense
Also, was the post from SultanHassanMasTuning about this last tune/log or something else? Becuase on the last one when you're idling it's in the 16-20* range on timing, which doesn't match what he was saying
Just asking for his opinion also............
I wasn't able to take the car out for a lengthy drive, however, I didn't know it would require that lengthy of a drive.
Like I said. I don't know what I'm doing. My wife keeps telling me to get rid of the car. That may be a better solution. Perhaps a new Z/28? It already has the track prowess I seek. They just cost too much.
Hell, I don't know what to do. I need another beer.
Anyone look over my latest? Should I go ahead and get rid of the car? Drive it into the river? We don't have steep cliffs here for me to indulge myself. :-/
lol, don't get rid of the thing. There ARE people who can fix it remotely for not a lot of money. I hate recommending people, because I always feel like it's on me if they suck, but I know there are people who can fix this for a reasonable price.
Def. not worth getting rid of the car over IMO
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
Two new logs from a cruise into work and back home. :-(
Just looked at cruise3 and I'm wondering why it isn't going into PE? Do you have the tune that you were using or is it one you've already posted?
There's at least one spot at > 50% throttle, 3K RPM's and >90kpa.. I would have thought those conditions would have been enough
What problems are you having now?
I just noticed that your commanded EQ ratio is going the wrong way in the one spot I found that looks like it finally went into PE.. that is backwards. I'm confused.
Can you post the most recent tune? Or email it to me if you haven't already?
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
I haven't looked at the scan but EQ Ratio is inverse of Lambda in the tune and IS lambda in the scan. It is like this in almost all the ECMs.
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Ok! I set Stoich back to stock settings and PE mode to stock. It calculates out to a final 11.52 AFR. Will that work better?
Here is the new tune now. How does it look?
I'm going to have to raise the idle somewhat. The car almost stalls out in gear.
I think the mistake was on my part.. your PCM reports commanded EQ ratio differently than mine does, so I thought you had set something backwards.. but it was actually just reporting backwards and I didn't know it. i.e. it's fine.
Here's what I would use on power enrich:
MAP 80 or 85 kpa
MAP hyst 5
enable 300
rpm hyst 30
PE throttle-->hot, set entire table to 5
EQ ratio (gas), I'd set the whole table to around 1.18 or 1.2 as a starting point at least
enrich ramp in, 1 is fine
PE delay, set to 1500
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Try using these values in your MAF table. Should be able to copy/paste the whole group at once
Make sure your units are in g/sec
nvm, I'll email it to you.
Might have sent you the wrong thing, but I just re-sent it. Changes are small so you won't see anything over maybe 5% difference. I was just trying to get fueling a little closer since I know how to help with that part
