I came across this thread earlier that might help some
http://www.hptuners.com/forum/showth...d-applications
Tuner by night
CPX Tuning
2005 Corvette, M6
ECS 1500 Supercharger
2007 Escalade, A6
Stock
I didn't read this whole thread but keep in mind there are many variables with the meth. I see many guys putting dual nozzle alky kits on 600 hp setups. It is just too much meth. When I had nozzles too big it was loading up with meth and getting very rich at the end of a run.
Julio recommends not running the controller on too low a setting, so the answer is trial and error to get the right nozzle(s) in there, not turning the setting too low.
As an example my PE is set for 11.5 across the board. The meth drops it to 10.8 across. If the meth is set up correctly.. the change in ratio should be fairly constant. I do run mine off the maf, rather than map, so that might keep it more constant also. Not sure on that one.
2007 Corvette C6 Vert. A6
LME LS402, Pat G custom cam, ATI 10% OD Damper
Circle D triple disc 2600, 3.42 Diff
YSI, 3.0 pulley, ID 1000's
Alky Control Meth,
ARH 1 7/8 headers,
1009 RWHP @ 7000, 817 RWT @ 6000
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Alky Control Meth,
ARH 1 7/8 headers,
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Alky Control Meth,
ARH 1 7/8 headers,
Here is a scan from the dyno. Went a touch lean right at the top which I now fixed by increasing the fuel via the BE table. Other than that is its pretty much flat all the way through. This scan was of a pull that made 1009 RWHP.
It takes some work and experimenting but you can get the fueling consistent.....as you can see.
Alky Control Meth,
ARH 1 7/8 headers,
Tuner by night
CPX Tuning
2005 Corvette, M6
2007 Escalade, A6
Stock
Alky Control Meth,
ARH 1 7/8 headers,
Is the white graph your commanded? How are you commanding methanol included? Is it because you tune in lambda?
This is the issue I have with AFR error % (commanded vs. actual). The error in my log is basically the difference of the meth.
I don't know how your doing it but it looks pretty good. I need to know how this is possible. Really curious as to how you have the meth set. By the look of your IAT, the meth comes and goes like I want it to, it does not hang around and saturate the bottom of the pull.
Tuning in lambda has advantages and is easier once you are used to it. The white is commanded, but I am not commanding meth included.
The commanded is .80 which is 11.5 .. exactly what I have in my PE table. The actual is .75-.76 which is about 10.8. the .7 difference is the meth.
If the meth is loading up at the end of a pull, I think it is because there is too much being sprayed. I had this issue with my last setup and going to a smaller nozzle fixed it. Now I run dual nozzles but its a bigger setup than before.
Alky Control Meth,
ARH 1 7/8 headers,
Found my notes.. Turn on is at 2. Initial is at 11.5
Alky Control Meth,
ARH 1 7/8 headers,
