Originally Posted by
schpenxel
The second picture is not quite right..
Clear everything out on that tab, then for the col(top) axis set the sensor to mass air flow frequency, unit to hz, then put these in for the labels.. Leave everything else blank on that page (should be same as you did for the fuel trim ones earlier)
1000,1150,1300,1450,1600,1750,1900,2050,2200,2350, 2500,2650,2800,2950,3100,3250,3400,3550,3700,3850, 4000,4150,4300,4450,4600,4750,4900,5050,5200,5350, 5500,5650,5800,6000,6200,6400,6600,6800,7000,7200, 7400,7600,7800,8000,8200,8400,8600,8800,9000,9200, 9400,9600,9800,10000,10200,10400,10600,10800,11000 ,11200,11400,11600,11800,12000,12200
Then add the AFRerror PID to the table display, same as you did with the MAF hz one a few days ago, and see what happens..
