2015 Dodge PCM Tuning is now supported!
HP Tuners is proud to release to the public a PCM modification service that unlocks the 2015 PCMs for tuning. The cost is 249 and can be purchased through http://www.hptuners.com/order.php at the bottom of the page.
Once ordered, send in the following:
- The PCM to be Modified
- Slip of paper with:
- Order # corresponding with "Modification Service" Purchase
- MPVI Serial Number
- Return Address
- Email Address
You can send either an original PCM or a spare. It is also recommended that you read the vehicle and send the file to support if you receive the "Definition Failed to Load" error before sending in the PCM. This will give me time to map out your file while your PCM is being shipped in.
An HP Tuners engineer will modify the PCM and enable your HP Tuners software so that the 2015 can then be read, licensed, edited, and flashed with HP Tuners software! This is a one-time modification that will not affect other operations of the PCM. The factory tools will still work for service. And HP Tuners will then work for tuning!
2015 model year Dodge vehicles can initially be read by selecting the "GPEC2A" as the PCM. Once the PCM is unlocked by an engineer and your VCM Suite/MPVI is enabled, the vehicle can be written to as a "GPEC2B"
Initially, please leave 1 - 2 business days (plus the time to ship the PCM) for the PCM modification.
Thanks!
