Bill,
No Prob,
The
fuel loop control averages the o2 sensor values to come up with an average o2 sensor value. This value is compared to the B1S1 and B2S1 tables to see if the fuel needs to be increased or decreased to stay at 14.7 AFR.
By telling the PCM to use a lower average millivolt value (350 instead of 451) it will drive the fuel correction lower and give you a slightly leaner air fuel mixture even though the o2 sensors are only correct at 14.7 AFR.
Think of it like your thermostat at home. If it's hot, the heater turns off, if it's cold it turns on. No midpoints just On or OFF. If you could average the temperature of your house and have the heater turn on and off "just when you are home" and keep it between 68-70 degrees, your heating bill goes down. These tables work in a similar way.
If you are in PE mode, the o2 sensors are ignored you just get more fuel period. If you are in Deep DFCO, the o2 sensors are ignored as well it's turning the fuel off instead of on. No feedback corrections just "On & Off" like the heater.
The General Airflow vs Mode determines which part of the B1S1 (or B2S1) vs Airflow table you are on.
The B1S1 & B2S1 tables determine how rich or lean the AFR might be biased.
BTW: If you are monitoring STFT+LTFT, and wideband AFR you will probably notice that the measured AFR in Closed loop moves around a bit with airflow at mild cruise & idle (check in steady state conditions). That's the bias that the B1S1 & B2S1 tables apply to achieve the correct AFR.
