Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: IVT Terms
  1. #21
    All good haha
  2. #22
    Jul 2016
    10
    Can someone weigh in on a Flex Tune? It has been tuned by a shop and shows 8.21, 8.54, 8.90, 10.18, 11.90 with Stoich Going from 14.7-8.9....7.92 across was how it used to be before E85
    2005 GTO
    LT Headers
    Vararam
    No mids or cats
    1 Piece DSS
    A4
    3200 Stall
    Cammed
    Stock 243
    Stock bottom end
    FAST 92 Intake
    LS7 Injectors
    E85
    BTR3 on order
    CNC 243s on order
    Morel Lifters on order
    .041 Head Gaskets On Order
  3. #23
    Aug 2009
    Calibrating
    3,373
    Quote Originally Posted by jandylee070601 View Post
    That is not correct at all!!
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
  4. #24
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Cut those in half
  5. #25
    May 2014
    23
    Those are the same AFR Term numbers my 2013 6.2 Flex truck has in the tune from the factory. I have a 2011 Camaro converted to flex using the same injectors as the 6.2 truck and I'm trying to determine if I should copy the AFR Terms over from the Truck to the car as the Camaro is currently 7.92 across the board. Any thoughts?
  6. #26
    Tuning Addict
    Jan 2015
    6,793
    Actually would like to know this myself - I've been setting up flex tunes just leaving the ivt's stock - if they need to be changed, which does seem to help with flex fueling - I would also like to know I was scratching my head on the above post - maybe thought Ben was thinking they were doing a double half setup, because it looked right from what little data was posted?
    ~Greg Huggins~
  7. #27
    May 2014
    23
    Anyone have info on these these. I tried changing mine from the standard gas nunbers 7.92 to the numbers go uses above for flex my trims went from 0 to -5 or -6 with the change. This is with E10 in the tank at the moment. These seem to have a great impact on fueling. Seems they could be important on a flex tune.
  8. #28
    Jan 2014
    Australia
    1,978
    higher values will increase the IVT calculation, i would think that too high will cause it to richen and too low would do the same so there should be a happy middle area..?
  9. #29
    Advanced Tuner jsllc's Avatar
    Sep 2015
    Bozeman, MT
    701
    This table is a multiplier to all the open loop commanded fuel tables after Ethanol blending based on a calculated intake valve temperature (IVT) and MAP.
    As an application example, if the commanded EQRatio "Open Loop Gas in Gear" was 1.130, and the value in this table was 1.110,
    then take stoic of fuel (1 / 1.130) / 1.110 = .7972 lambda (assuming gas approx 11.70:1 AFR)
    or (1*1.130) * 1.110 = 1.2543 EQratio (assuming gas 14.68/1.2543 or 11.70:1 AFR)
    Stoic
    0 6.25 12.5 18.75 25 31.25 37.5 43.75 50 56.25 62.5 68.75 75 81.25 87.5 93.75 100 %
    Stoich 14.67822 14.32227 13.96582 13.60986 13.25293 12.89697 12.54102 12.18408 11.82813 11.47217 11.11523 10.75879 10.40283 10.04688 9.689941 9.333984 8.978027
