I have been getting P015B and P015D(O2 Delayed Response) since installing Kooks headers on my 2012 Camaro ZL1. I had read in some other threads that increasing the airflow integrator delay might solve this because of the greater distance to the O2's. It hasn't worked. Codes still come back. Tried increasing the table by 35% and then by 50%. Has anyone had luck with this table with long tube headers? Should i just give up and turn off the codes? Or I am going the wrong way and should decrease the integrator so the O2's switch faster? FWIW I still have the Kooks Cats on it.
Also installed a 9.55 pulley and working on the tune for that as well. Any advice? So far I changed the MAP Boost disable to 250Kpa and enable to 240 Kpa and the boost doesn't cut out anymore. As well as pulled about 5 deg advance in the lower right quadrant of the high octane spark table to be safe at first. All the LTFT still looks like stock so I haven't messed with the MAF table yet. Also changed the fans to come on sooner. So very minor changes so far and it runs very strong. So what else should I look at besides fine tuning the High Octane Spark and PE?
