Results 1 to 20 of 22
Thread: Failed Emissions Test ???
    Dec 2008
    Pearland,Texas
    33
    Well I have a 2011 SS/A6 Camaro with a Cam, Blower, full exhust and cold air kit. The inspection went out so I took it in. I had no MIL lights on and the car runs like a champ. They do the inspection only to tell me it failed due to... Evap not ready and EGR Sys not ready?
    Can anyone give any advise as to what or why this is ???
    Thanks.
    Darkside, AZ
    123
    They are failing your car because of the GM readiness monitors. Some states only allow a max of 2 monitors not-ready depending on the year.
    You will need to do a couple of GM drive cycles which consists of these specific instructions...
    1. Cold Start. In order to be classified as a cold start the engine coolant temperature must be below 50°C (122°F) and within 6°C (11°F) of the ambient air temperature at startup. Do not leave the key on prior to the cold start or the heated oxygen sensor diagnostic may not run.
    2. Idle. The engine must be run for two and a half minutes with the air conditioner on and rear defroster on. The more electrical load you can apply the better. This will test the O2 heater, Passive Air, Purge "No Flow", Misfire and if closed loop is achieved, Fuel Trim.
    3. Accelerate. Turn off the air conditioner and all the other loads and apply half throttle until 88km/hr (55mph) is reached. During this time the Misfire, Fuel Trim, and Purge Flow diagnostics will be performed.
    4. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for 3 minutes. During this time the O2 response, air Intrusive, EGR, Purge, Misfire, and Fuel Trim diagnostics will be performed.
    5. Decelerate. Let off the accelerator pedal. Do not shift, touch the brake or clutch. It is important to let the vehicle coast along gradually slowing down to 32km/hr (20 mph). During this time the EGR, Purge and Fuel Trim diagnostics will be performed.
    6. Accelerate. Accelerate at 3/4 throttle until 88-96 km/hr (55-60mph). This will perform the same diagnostics as in step 3.
    7. Hold Steady Speed. Hold a steady speed of 88km/hr (55mph) for five minutes. During this time, in addition to the diagnostics performed in step 4, the catalyst monitor diagnostics will be performed. If the catalyst is marginal or the battery has been disconnected, it may take 5 complete driving cycles to determine the state of the catalyst.
    8. Decelerate. This will perform the same diagnostics as in step 5. Again, don't press the clutch or brakes or shift gears.
    And remember, NO TUNING or CODE Clearing until all of your monitors have passed. You can verify by scanning for codes with HPTuners. BUT DO NOT CLEAR CODES or you will reset everything again.
    1997 Black Curse SEi, 4th Engine, 2nd trans.
    2000 Chevrolet Blazer LT 4.3L
    2002 Chevrolet S-10 LS 5.7L
    Apr 2011
    42
    Isn't there a way to turn off the readiness monitors in hp?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,862
    Pretty sure your car doesn't have EGR. Are you sure that showed as failed?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Dec 2008
    Pearland,Texas
    33
    DSteck, I dident think that there was a EGR but on the sheet it showed as a not ready.
    Darkside, AZ
    123
    Even if you were able to turn them off, they would still show as not being ready.
    Dec 2009
    1,084
    There is a way to make the "ready" even if your car doesnt have them.
    Dec 2008
    Pearland,Texas
    33
    Do tell my friend
    Dec 2009
    1,084
    Forget exactly but think it has to do with setting certain Dtcs to 3
    Then checking the IM readiness on the scanner to besure.
    Dec 2008
    Pearland,Texas
    33
    Any ideas DSteck ???
    Apr 2009
    613
    Set all codes that apply to the egr and evap (tank pressure, vent, purge etc) to no error reported and then recheck your readiness monitors. They should pass as soon as you reconnect.
    1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
    - 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
    Darkside, AZ
    123
    I really don't think that will work.
    But it wouldn't be the first time I learn something new.
    Apr 2005
    Sugar Land, TX
    1,198
    This works on my 08 Corvette LS3. Just look at the DTCs. I pass every year!
    Dec 2009
    1,084
    Quote Originally Posted by flame View Post
    Quote Originally Posted by Mike1995 View Post
    Yes I am pretty sure this is what will work.
    Dec 2008
    Pearland,Texas
    33
    Quote Originally Posted by 8850 View Post
    Wow and it still runs ? Do I just do the ones for the EVAP and EGR or all of them ?
    Apr 2005
    Sugar Land, TX
    1,198
    Quote Originally Posted by Stic It View Post
    Sure it still runs. In fact zero difference. Cars from the 50s and 60s had no DTCs and they ran. You can probably find the codes that will make the car pass but I got tired of trying so many combinations, gave up and disabled all. When I get back home from inspection I re-enable.
    Dec 2008
    Pearland,Texas
    33
    Done brother, passed with flying colors
    THANKS TO ALL WHO GAVE INPUT
    Dec 2009
    1,084
    Sweet!
    Glad it worked out for ya.
    Apr 2011
    42
    Yay, there was a big thread about doing just this on css.net so i knew it was possible.
    Darkside, AZ
    123
    So your saying I can zero out all my P codes and NY won't know the difference even with my monitors?
