Results 1 to 8 of 8
Thread: spark tuning and cylinder airmass
    Aug 2012
    Huntsville, AL
    122
    Just curious about how you guys are doing your spark tables. How are you logging the cylinder airmass in g/cyl? Is dynamic cylinder air the same thing?
    Jason
    01 Camaro Z28 LS3 525hp Built 4l60e
    74 Camaro Z28 LT 355 fully forged roller with t56 4.56 gears
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    Yes, use dynamic cylinder air.
    Spark tables are tricky and there is no easy explanation to it other than put the car on the dyno and find the lowest spark value to use that makes the best power. For example, if at WOT 25º makes 425 hp and 29º makes 427 hp, stick with 25º. Just my opinion.
    Sulski Performance Tuning
    Aug 2012
    Huntsville, AL
    122
    Quote Originally Posted by WS6FirebirdTA00 View Post
    I can understand but I don't have readily available access to a dyno.
    I think when I used dynamic cylinder air PID against the tables it was off by a large number. Like one was reading .045 and the other was reading .69 (.045/.69 is a bit of a big difference) so I figured they were referencing something totally different from one another. I will go back and look through it tonight when I get home.
    Jason
    Aug 2012
    Huntsville, AL
    122
    So is the dynamic cylinder air an accurate source of information to get data from or does it get information from a formula from various sensors that needs to be calculated? Does the MAF need to be tuned and running for it to be correct or does it gather information from the MAP? I guess that's what I'm asking. I don't want to be using it for correct information if that information is not correct yet.
    Jason
    Jan 2005
    Concord, NC
    8,093
    You have to have your fueling tables for it to register correctly. That is how it gets your g/cyl.
    Aug 2012
    Huntsville, AL
    122
    Are you talking about just the VE tables or are you including the tabs under the Fuel tab (i.e. General, Cutoff/DFCO, OL&CL, PE, COT, Transient)?
    I'm pretty sure I have the majority of stuff under the Fuel tab correct. I'm still dialing in the VE table 100% but I'm pretty much at around 90 - 95% on that now.
    How is it using fueling tables to calculate airmass in the cylinder? Not that I'm questioning you, I just would have thought that it derived it from MAF or the MAP since they measure airmass going into the engine.
    Jason
    Dec 2011
    Melbourne, Australia
    82
    Quote Originally Posted by kyphur View Post
    hard to tell what tables your specifically talking about but the number 0.045 sounds me me like delta cyl air, which is change in g/cyl, if the g/cyl changes too quickly the ecu with pull timing as per your instructions
    stock 99' LS1 + powerglide
    gt42 a/r 1.06
    #80lb siemens @ 43.5psi rail pressure on E85
    return fuel system runing 1:1 FPR
    aeromotive A-1000 pump
    2 bar SD tune
    Jan 2005
    Concord, NC
    8,093
    Injector data needs to be correct of course, but also VE and MAF
