Results 1 to 20 of 24
Thread: looking for some advice on...
    Tuner in Training awdhurst's Avatar
    Jul 2012
    24
    having some issues with this tune. while driving it, the engine keep surging up and down about 40-60 rpm. here is a few hpl files
    the 8th run.hpl is where I broke the super charger belt. dang
    Apr 2009
    613
    Your LTFT are hitting -24 finish tuning it and I'll bet your problem will go away
    1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
    - 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
    Jul 2012
    24
    Quote Originally Posted by flame View Post
    What should I set it to??
    Advanced Tuner oakley6575's Avatar
    Aug 2011
    421
    Post the tune. And Flame is right. Your fuel trims should stay around 0. -24 is dangerous
    2003 Chevy Silverado Daily Driver, 408 Iron Block,
    LS3 Heads/Intake, 231/239 114, 4L80e, Yank SST 3200.
    Apr 2009
    613
    You need to adjust the VE table and MAF if you have one until your fuel trims are within 2-3%
    Jul 2012
    24
    adjusted the LTFT boundaris for the map and rpm. it helped the throttle respones alot . not exatly sure what numbers to put in the VE and MAF
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    Quote Originally Posted by awdhurst View Post
    Use your WBO to generate a correction factor for fueling. You are running an E67 ECM with a Trailblazer tune. Many using HPT would run a MAF only tune - as the VE (or VVE - depending on your point of view) tables often overwhelm the less experienced tuner.
    Also, your 2007 tune uses a Low and a High MAF table, in 2008 these were homogenized into a single table (my preference). When altering the 2007 MAF tables - make sure the highest column in the Low table (5800 Hz) has the same values as the lowest column in the High table (5800 Hz).
    Jul 2012
    24
    Quote Originally Posted by Shrek View Post
    something like this
    Sep 2011
    301
    You are tuning a boosted ls2 and you don't know how to tune the ve/maf table?
    Learn some basics before you blow that thing up! You should have a wideband that is logged against your VE and MAF tables so you can ensure the fueling is proper.
    Aug 2011
    421
    Your going to blow this thing up. You can't tune boost without a wideband. There is no way of knowing what your fuel mixture looks like until you hear a BANG
    Jul 2012
    24
    Quote Originally Posted by BigMike42 View Post
    I have a wideband on here showing between 14.3 to 13.8 while cruzing at 65.. 2500rpm just dont have connected to the hpt .
    Jul 2012
    24
    thats why im here looking for some help.. thanks
    Jul 2012
    24
    Thanks for you help
    Aug 2011
    421
    You need to hook the wideband up to HPT. That way you can log lambda error and tuning is soooo simple.
    Sep 2011
    301
    First things first get a wideband and make sure you can view it in hptuners. Dont do anything until you have that.
    Jul 2012
    24
    what would be a good gauge setup?
    Jul 2012
    24
    small adjustments
    Aug 2009
    Calibrating
    3,374
    Don't go WOT your PE table is not commanding enough fuel your around 13.3 AFR (nor is your MAF from what I can tell)
    Your limited by the 512 G/sec limit too, going to have to have a scaled tune or the PE table is going to have to be modded. Since your a centri blower REALLY either would work, but one is the more professional way of doing it.
    Tune needs a lot of work
    EDIT: Looked at a pull you did, don't go WOT again your maxing out the MAF G/sec limit at 4400 and your shifting it 6000+ with a PE table commanding 13.0 AFR (you have stoich as 14.3).
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Jul 2012
    24
    testing the wb02 input
    testing the wb02. It shows up on the table display and the chart display. How do I get it to show up on the histogram chart? or is it not suppose to?
    Tuner in Training Alain2's Avatar
    Feb 2012
    New Brunswick, Canada
    17
    You have to add it to the chart settings and histogram settings configuration.
    2003 Corvette Z06 346ci LS6 Supercharged A&A Vortech T-trim 9 psi, 60lbs injectors, 556 RWHP & 466 RWTQ, summer daily driver.
