My car :
stock 2000 LS1 FI - Vortech V3 Si Trim & 3.4" pulley - on E85
60 injectors
255lbs legenfilter fuel pump
Have change stocio from 14.7 to 10.06
Look at my number on drag strip - 1# run, full logging :
Time.... - Gear - TPS - %INJ Duty - RPM. -WB AFR- PE in tune
5:26.312 , ...1 , 100 , .......93 , 5534 , 11.76, 1.510@5600
5:26.531 , ...1 , 100 , ......142 , 5976 , 12.58, 2.156@6000
5:26.718 , ...1 , 100 , ......178 , 5730 , 13.96, 1.510@5600
5:28.328 , ...2 , 100 , .......87 , 5462 , 12.37, 1.510@5600
5:28.531 , ...2 , 100 , ......105 , 5659 , 12.69, 1.510@5600
5:28.750 , ...2 , 100 , ......136 , 5866 , 13.01, 2.156@6000
5:28.953 , ...2 , 100 , ......161 , 6081 , 13.36, 2.156@6000
5.31.140 , ...3 , 100 , .......92 , 5479 , 12.54, 2.156@6000
5.31.390 , ...3 , 100 , ......102 , 5552 , 12.64, 2.156@6000
5.31.593 , ...3 , 100 , ......105 , 5674 , 12.53, 2.156@6000
5.31.812 , ...3 , 100 , ......122 , 5734 , 12.77, 2.156@6000
5.32.000 , ...3 , 100 , ......129 , 5850 , 12.88, 2.156@6000
5.32.218 , ...3 , 100 , ......144 , 5950 , 13,08, 2.156@6000
5.32.406 , ...3 , 100 , ......154 , 6054 , 13.23, 2.156@6000
5.32.609 , ...3 , 100 , ......167 , 6129 , 13.48 (32.8 msec INJ. Pulse Width Avg on each Bank)
Average WB AFR in 5400-5799 range for the all run in 100 TPS : 12.62 (1.510@5600)
Average WB AFR in 5800-6199 range for the all run in 100 TPS : 13.09 (2.156@6000)
I wanted hit 12.1 AFR, i have change PE for the #2 run :
Average WB AFR in 5400-5799 range for the all run in 100 TPS : 13.00 (1.547@5600)
Average WB AFR in 5800-6199 range for the all run in 100 TPS : 14.65 (2.246@6000)
note : very lean afr on this run !
I always wanted hit 12.1 AFR, i have again change PE for the #3 run :
Average WB AFR in 5400-5799 range for the all run in 100 TPS : 12.67 (1.607@5600)
Average WB AFR in 5800-6199 range for the all run in 100 TPS : 12.62 (2.449@6000)
I have change PE for the last run of the weekend :
Average WB AFR in 5400-5799 range for the all run in 100 TPS : 12.7 (1.681@5600)
Average WB AFR in 5800-6199 range for the all run in 100 TPS : 13.8 (2.557@6000)
No other run for this weekend
First, i dont anderstand how hptuner calc %INJ Duty only with msec INJ. Pulse Width Avg on Bank ??? (stock i'm with 26lbs, with A&A kit i'm with 60lbs, but HPT scanner dont know this !)
Second, i cant be able to min my 12.62 afr for 5400-5799rmp range, 12.62 with 1.51 PE... and 12.7 with 1.681 PE, look like i need change 60 injectors for bigger, or need upgrade fuel system (remember, it's a 2000 corvette, i have just put 255lbs legenfilter fuel pomp), or stop use E85 ! ???
What do you think about that ?
