Hello everyone,
Im trying to understand the MAP sensor settings for a 2BAR SD tune.
I have installed a GM 12615136 into my LS1, upgraded to the HPT 2BAR OS
I have tried to get the MAP dialed in and having no real luck.
What i am trying to understand is how people arrived at these numbers.
My understanding is when you have the car off the MAP should read from 100-102KPA
Right now mine is reading 99KPA, I know that’s pretty close, will that be close enough is the first question. Next question is when I upgrade to 2 BAR it automatically changed my values to 200KPA and offset of 8
I understand the Offset of 8 since that is the KPA reading for that sensor a 0Volts.
But what I don’t understand is why does the sensor only goto 200KPA at 5Volts when according to the technical specs its approximately 208-210 KPA at 5Volts
Can anyone explain to me why we are recommending?
200
And offset of 8.
Or is this just a good starting value and we should be modifying these values until we read 101 KPA with the car off.
My current values are:
208
And offset of 8.33
Am I out to lunch or is this more accurate?
