I set the Pe like that so it would hit it early for safety while tuning it and getting the fuel up top correct. I would much rather be safe than sorry with another persons car. I will set it correctly when the tune comes together a little more. It has a lsj throttle body so I set the ETC scaler and effective areas up like a lsj, isnt that the correct way to do it? It does have a complete lsj intake set up.. Its running a 2.9 pulley as well with a header and full exhaust so it moves some air. As for right now the injectors were maxing out up top and causing it to go lean any time after 5500rpms sometimes earlier. I will be aiming for a steady 11.5 afr to keep things on the safe side. It also seemed to not like a much leaner afr. It would missfire and stumble when going as lean as 12.0. He ordered a good set of 60s for it today so that should help give a little more room fueling wise when they get here. He has another mechanicle issue that is causing the idle to hang and the throttle body stay at 20% unless you hold the brake while in gear. I think its a vacumm leak somewhere. Thats part of the fun when trying to tune a car thats not ready. That tune is far from finished and correct but I do appreciate the help a lot. As for the daily driving part I did get the maf dialed in for how its running and worked the spark tables. Is there anything else yall see that needs to be changed that im missing?
