I have some 60lb Mototron Injectors (long ones if that even matters) and Im suppose to have the correct injector data. but on my last log the IPW at idle was 3.0, and its suppose to be 1.6-1.7
Here is my tune
I adjusted the Short pulse adder on this tune to a lower value initial value was twice the value in the tune.
I don't want someone to give me values, just some general info.
I know making the Offset tables smaller= leaner
And I believe decreasing the short pulse adder table = decreased IPW
(hence the lower values in the new tune)
Lastly with Fuel pressure, the IFR table (boost referenced) should be setup based off running idle pressure (mine is set to 50, and runs at 43 at idle)
Do I sit it up for 50 or 43?
Thanks for anyones help, just really stuck right now, can't tune the car till I get this corrected.
