Results 1 to 9 of 9
Thread: 4.3 to a 5.3
    Advanced Tuner =fast='s Avatar
    Jan 2009
    396
    4.3 to a 5.3
    Ok guys this is the first v6 truck that a converte to a 5.3, i got everything the harnees and a 5.3 computer install, whta my next step should i just disable vats and then buy credits n tune it?
    May 2010
    8
    Yep. Disable VATS and fire it up. If you have the computer and harness out of a 5.3 already should'nt be much to do to fire it.
    Jan 2009
    396
    Ok i did it but im not getting power to my injectors, it turns on but it dies....?
    May 2010
    FrankFort
    50
    Sounds like VATS.
    Jan 2009
    396
    Thats what im thinking, i did it several times and does the same thing.
    Feb 2006
    central michigan
    349
    or the fuel pump relay is not seeing an oil pressure signal.
    Tuner copley87blazer's Avatar
    Mar 2011
    Wilder,ky
    131
    what do you mean it turns on then dies. Does it start and run for around 3 sec and shuts off If so its vats
    Jan 2009
    396
    ^^^Yes it turns on around a second then dies, Im disable the vats how it shows it in he help file (F1)...
    Potential Tuner Timm's Avatar
    Nov 2010
    Davison, MI
    7
    Sounds like the fuel pump isn't getting the OK to stay on after the truck is started. Like others have pointed out, it sounds like a security issue. Although I wish I had more info on what needs to be done to disable it. Hopefully someone with 5.3 v8 PCM knowledge will chime in! Congrats on the swap! It'll be even cooler when it stays running! (Been in the same position as you with my 3100 -> 3800 swap.)
    2001 Impala LS: 3.8L Top Swapped with GenV Blower, ZZP XP Cam, and with nearly 250,000 miles.
    1995 Cutlass Supreme Convertible: Engine swap to 3.8L Supercharged.
