Results 1 to 9 of 9
Thread: 1st LNF tune
    1st LNF tune
    Im lost here trying to tune my first LNF. I haven't really been tuning much GM stuff in the last couple years. This little turbo toy is confusing.
    I think I get the Pe table
    lambda = 14.68
    so 14.68 * .76 = 11.2 commanded AFR?
    I have tuned some supercharged cobalts so it isn't all greek. Anyone have something I can look at for a stock car? I downloaded the file in the respository and tried it. It stayed in the 13's on the dyno well into the rpm range and I stopped pulling the car.
    Where do these things like to be air fuel wise? Looks like 10-12 degrees of timing works best at 15++ PSI. If someone can point me in the right direction I would appreciate it.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,285
    on the DI motors a 13:1 afr isn't uncommon.
    Apr 2007
    16
    I run my personal LNF car at a 12.6-12.8 or a .88 lambda at WOT I also run 21-22* of timing on pump 93 at 22.5psi!
    Which is all we can do since HPT hasnt' unlocked our wastegate or fuel pressure tables....
    WINK WINK
    Jul 2009
    Winfield/Ofallon MO
    600
    Stock HHR with 93 octane i was running 22ish boost, holding 19-20 to redline, redline at 7k, and about 18* timing up top.
    Quote Originally Posted by Jaxon View Post
    I think I have a half way decent file put together at this point. I downloaded a few histograms and config files. I will continue to play with it. I haven't got it to hold anywhere near 18 degrees up top. 14ish with top tier 93 octane.
    Can you post your file so I can see what I am missing.
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Fuel trims being off causes knock, work on the fuel trims.
    Jul 2009
    Winfield/Ofallon MO
    600
    I was also running 18* in the summer, winter blends suck. Im running 14* on 24psi right now but I have bolt ons aswell(never tried more than 14* on 93oct) BTW, dont use QT gas, it blows. Its 93 here but I was getting PLENTY of KR on it.
    Senior Tuner BackyardTurbo_FTW's Avatar
    Jul 2009
    East Suckburg, PA
    1,163
    The tune in the repository is good, I would just change the intake cam warm table to a stock one and then tune the MAF. .88 is a good place to be
