Results 1 to 6 of 6
Thread: 2002 TA 408 F1A Procharger
    Dec 2010
    2
    Hey guys i have a 2002 TA. It has a 408 stroker. the procharger is a f1a only on about 12lbs. It has a msd 3 bar map sensor. it has 80lb injectors with a complete aeromotive fuel system. still has the maf on it now but when i get it dyno tuned i will be going speed density. it has a turbo 400 trans.
    I was wandering if anyone has anything close to this so i can download a tune to my car just to make it run and idol so i can get it on the trailor to get to the dyno. i have hp tuners but i am new to the tuning and i was wandering if someone has something close to this that will make my car run to get on and off a trailor. if u do can u send me the tune so i can put it on my car if thats possible.
    thanks
    Dec 2010
    2
    forgot to mention that it is a turbo 400 trans.
    Sep 2009
    346
    Wandering? Idol? Trailor...
    hmmm..
    I would not get my hopes up that someone is just going to give you a tune, that perhaps matches what you have done. There are just too many variables at play.
    There is a tune repository available when you log in to the HP Tuners Customer site. (Main Page) where you could copy over some tables if someone has something similar. (not sure if that is a proper approach)
    Your best attempt would be to do some reading on FI start up threads where as you add values to Base Airflow tables for example, just to get it running and go from there.
    Does the vehicle idle or start?
    Advanced Tuner TheDastardlyDuo's Avatar
    Apr 2005
    IL
    244
    Here's a file from a 418 with a YSI 18lbs of boost 3bar TH400 with a Magnafuel fuel system, FIC 85lb/hr Injectors, should be close enough to get you started.
    Aug 2006
    5BA8
    3,253
    Couple things. First, why 3 bar if you're only 12 psi? Second, I don't think it will run with the 3 bar in MAF mode. you'll need to go ahead nad apply the OS now, if the MAP is wired in. If you use the posted tune, make sure you get the VE right. His is a 2 bar, and you're using a 3 bar.
    EFI specialist
    email=[email protected]
    Apr 2005
    IL
    244
    The VE table goes to 315kp as does the Boost Enrichment table, should be 3 bar.
