Hi,
where are the settings for using the WOT tables for the A6.
At the A4 there were two parameters for "Full Throttle Enable"; Enable TPS and Disable TPS.
How can I adjust these on the A6 tranny?
Birger
Hi,
Birger
The A6's dont have this option to disable WOT or enable WOT.
2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
2011 Ford Taurus SHO - stock with just a Tune
Ah, I see.
So there is no way to set WOT at 85% or 90% throttle and normal below 80% ?
Go to trans/auto shift speed and take a look a normal/ pattern A/ pattern B. is all in there. depending on how on your shift pattern type is setup in the shift properties tab, pattern A or Pattern B can be either normal or sport. in the G8GT pattern A is sport. in the Camaro 2010 i believe sport would be pattern B.
Match the WOT colums for the full trottle (WOT mph) stuff according to whatever you define in the last 2 cells for the part throttle stuff.
