Results 1 to 12 of 12
Thread: Gen IV Real Time Tuning
    Dec 2005
    Verona, WI
    144
    I've done a search and there was an older thread from a year ago asking about RTT for gen 4 vehicles. The reply then was it was not in the plans at that time. Is this still the case or has RTT made it on the map for gen 4 vehicles now? For me the main portion of tuning that seems like it would be most beneficial for RTT is when tuning the timing. Being able to adjust the timing on the dyno and see instant torque read outs until you find MBT would be really nice.
    Thanks.
    still no plans
    I count sheep in hex...
    Dec 2005
    Verona, WI
    144
    Thanks for the update.
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by Nick 2K2 SS View Post
    Thanks.
    You can do spark-hook with the VCM controls in the scanner though right?...
    Steve Williams
    TunedbyFrost.com
    Dec 2005
    Verona, WI
    144
    Quote Originally Posted by Frost View Post
    If by spark-hook you mean adjust the timing using the VCM controls...then yes you can...somewhat. On my GXP, the only timing control I have through the VCM controls is in the minus direction, in otherwords I can only remove timing, not add timing.
    Unless spark-hook means something else?
    Jan 2006
    Richmond VA
    1,950
    Spark-hook is the name of the process of determining the steady state value that produces the most tq.
    The Bi-di controls allow you set timing to a static value and have some buttons to increment it up and down. I have never tried to use the bi-di's on an e67, so I wasn't 100% sure that they worked.
    Steve Williams
    TunedbyFrost.com
    Yeah, you can only take timing away.
    Feb 2006
    athens, ga
    26
    Just wondering if yet anoter? year later RTT was on the board yet for gen IV's?
    99 red ss m6: 1 1/4 drop, aluminum flywheel, Mccloed adj master, B&M riper w/ cut stick, 4.10's, eradi speed rotors w/ hawk pads, Hp Tuners, LM-1, FAST 90/NW 90, Kooks LT's, costom 3" true duals
    1/4-13.6 @ 101 mph stock
    LSX Perfomance
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,287
    Not on the roadmap at this point.
    Jun 2008
    Charleston, SC
    969
    Quote Originally Posted by JonCR96Z View Post
    add 5 degrees to the area you want to tune, then remove it with the vcm controls, that gives you a +5/-5
    -Carl
    what's on the road map these days?
    Sure are hearing about what's not
    HP Tuners Support
    (foff667)
    28,287
    Quote Originally Posted by Phil'sC5Vette View Post
    Dodge NGC3, NGC4, JTech, GM E39, E78, more E38, E67 custom operating systems, etc. Hard enough keeping up with new pcm's that come out from gm, ford, dodge to find time enough to even look into things like real time tuning for other gen vehicles.
