I searched for answers on this thoroughly and came up with a 0.
I am wondering if anyone is using just the Kavlico or autometer 2246 raw sending unit with the pigtail and logging it with the EIO. I am interested in doing that, but the input is 5v. I know I can tap any of the many 5v sensors to get my 5v, but the data sheet mentions the max draw for the sensor is 5 amps and I am concerned with interfering with the 5v bus from the PCM or any of the sensors outputs. I sent an email to Kavlico for clarification to see if the current draw is based on the output impedance. If it is, then I will be fine. If not, I need to hear from you guys to know what you're doing for this.
Here's the data sheet. Autometer uses Klavico sensors.
http://www.kavlico.com/_assets/pdf/P255DS.pdf
I will post up the answers from kavlico
