Results 1 to 11 of 11
Thread: Bad day at the dyno-need help
    Jan 2009
    3
    My setup is as follows..
    76 Corvette
    LM4 5.3 aluminum block
    T56
    LS6 intake
    1-3/4" LT headers
    4.11gears
    HP Tuners
    GS392 fuel pump
    Took the car to the dyno sunday(I will have the graphs in the next day or so) all 3 pulls made about the same 255whp. This setup should be making around 290-300whp. Didnt even read air/fuel up until 4500 rpm, running super lean. I knew something was up which is why I took it to the dyno. 1st gear just didnt have as much pull as I thought it should, just feels dead. Shift to 2nd and it pulls hard, mainly because it doesnt fall below 4500.
    Are the ls6 injectors different from the 5.3? What could be the reason for running so lean? If anything I thought the setup would run rich at first. Im running the 5.3 maf by the way.
    May 2009
    27
    LS6 injectors could either be 28.8lb/hr or 26 lb/hr. depends on the part number. Did you adjust the injector tables to reflect the swapped injectors?
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    Why would you go to the dyno without doing some wideband street tuning first? Waste of money.
    Post your tune and the log.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Jan 2009
    3
    Cheap dyno day man..sorry, Iv got 30 bucks to blow..I honestly didnt think the car would be THAT far off. Like I said if anything I thought it would be rich and not lean. I dont have a wideband yet, just havent gotten around to buying one. It runs clean besides me kinda thinking it doesnt feel right accelerating in first. I did not adjust the tables for the different injectors. Here is my tune and a decent log file.
    Attachment 18355
    Attachment 18356
    Oct 2007
    983
    Well, after a quick look through the tune, I would scrap it and start fresh with a stock tune.
    PE table looks bad.
    AFR Stoich table hacked.
    Injector flow rate table wrong.
    Spark tables need work, timing is being pulled by IAT and added by AFR Advance.
    CAT is still enabled, I am guessing you don't have catalytic converters
    Are you using a electronic throttle? If so, the data being shown in the. PID table is way off.
    Not a good tune to start with.
    Get your wideband and start fresh.
    LS1 Tuning Guide
    Tuner gr8vet's Avatar
    Aug 2008
    Sunny South
    53
    Yea, tune is crap. Id scrap the whole car myself. Did you do this? Jezzzz.
    I'll fix it fer ya.
    Get me the number off your injectors so I can verify.
    Later
    tt
    Jan 2009
    3
    Here is the stock tune minus turning off vats. The only table I have touched since then(previous tune I posted) is TQ management tables, dtcs, added 3deg timing across the board and the gear change table. I havent touched any fueling tables. or anything else. Kinda weird. I would appreciate you fixin it up!
    injector numbers 12561462
    Attachment 18366
    Feb 2007
    San Antonio, TX
    1,255
    Quote Originally Posted by ellis juan View Post
    Here is a start for those with Hp Tuners available...I'm at work so no scanner/editor to get you taken care of yet.
    Delphi / Bosch
    28 lb / hr Injector
    Part Number 12561462 (Bosch # 0 280 155 931) - This is a LS1 factory GM injector.
    Static Flow Rate: 28 lb/hr (294cc) @ 43.5PSI (300kPa)
    Fan spray pattern for superior atomization.
    High pressure capability
    High Impedance / High-Z
    Update: Disregard above folks. Looks like bad info. from here -->>> http://www.ls1tech.com/forums/ls1-do.../t-447226.html
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
    I am not sure where that data comes from, but to the best of my knowledge those injectors (LS6) are rated at 28.8lb/hr @ 4 bar (58psi) not 3 bar (just check a stock LS1/6 tune that has those injectors and that would get you what GM uses at least and IIRC it is about 29lb at zero vacuum. 3 bar would put them closer to LS2 injectors in vicinity of 33lb/hr. What is the IFR set for now - cant view tune right now
    Oct 2007
    983
    258cc @ 3bar
    24 lb @ 3bar (43.5)
    27 lb @ 4bar (58)
    http://www.witchhunter.com/flowdatapix/b0280155931.jpg
    LS1 Tuning Guide
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    The 5.3 Z (flex fuel) engine has larger injectors, your IFR is correct for the stock injectors.
    Russ Kemp
