Results 1 to 4 of 4
Thread: afx wideband Question
    Apr 2009
    saint clair shores mi.
    17
    newbie here, have a question -what is the ground offset you are using . or if you are using a predefined PIDs in the scanner?
    also when you calibrate the wideband do you turn the nob till it reads a number mine reads 16.00 when i turn the nob on the display controller is this correct?
    so do i leave it there for 5-10 minutes then turn nob till it reads cali-
    is that all you have to do?
    thanks.
    Tuner in Training trx2stroke4life39's Avatar
    Jan 2009
    newburgh, ny/ scranton, pa
    30
    You turn the knob until it reads cali-.
    I am using the PID in the scanner and then you fine tweak it until it is correct.
    2001- Silverado 4.8, coldair intake, custom catback, headers, Stohner Tuned
    2003- durmax dads truck.Yet to be tuned completely.
    Jul 2004
    1,579
    Did you read the instruction that came with the wideband? It clearly states what you need to do. As for logging with HPT, I use the native PID when logging.
    Tuner in Training 346ci's Avatar
    Aug 2008
    37
    The manual tells you how to calibrate the sensor. Turn the knob until it reads Cal-, power the sensor up and let the sensor hang in free air for 30 minutes or so,the longer the better according to the manual.
