Hey guys,
My head hurts like hell from work, and I am finding it hard to think. Sorry if everything is long winded…
My name is Andrew, and I am from Greenville, South Carolina. I am on my 3rd LS1 car and I am just getting into tuning. I am currently tuning my 99 Trans Am.
Could someone check out some of my tunes, logs, and methods? Maybe comment on them? Basically i want to see if I am headed in the right direction, and maybe get some help with some common problems.
I did have this posted in the Geting Started section, but decided to post this over here to see if it will get more publicity.
Sorry if I jump around, but I have a lot on my mind. I am tuning in SD mode and had some concerns. Here is some info that may help:
Mods:
230/236 .613/.601 112+3 Cam
Supporting valvetrain components (Double springs, 7.4 Hi-Tech pushrods, LS7 lifters, LS2 Timing chain)
LS6 Intake Manifold
30# SVO redtop injectors
Ported LS6 oil pump
Underdrive pulley
Pace Setter LongTube Headers
Pace Setter Offraod Y pipe
Magnaflow catback
3.90 rear gear
I am using an LM-2 Wideband through the EGR connector to log AFR.
I had my VE table below 4000 rpm pretty much dead on before the temperature change, and close at WOT at most RPMS as well. Last time I logged it was in the 60's, it was around 80 today.
Everything feels great about the car, idles good, starts up fine, feels strong how I have it now.
But, I have bucking at light throttle below 2000 RPM. Even when I had it with the professional tune loaded when they appeared to have only tuned the MAF.
Tuned by a Mustang shop in Pensacola, FL before I bought the car.
I will attach the “professional” tune as well.
I had lots of bucking on deceleration below 2000 RPM. Once I zeroed out the Throttle Cracker at 400 and 1000, and lowered the numbers in the 1600 column, and the rest, the deceleration bucking is almost completely gone except below 1500, but it’s a lot better.
The car Idles great when using the RAF that was in the "professional" tune. But when I use the RAF tuning histograms supplied on this forum, I get lower numbers in the warmer temps than I think should be there. The car doesn’t want to start up when warm and the idle dips with my RAF tuning. Again it seems fine with the "Professional Tuners" RAF table. I used RedHardSupra's MAF spreadsheet to calc my new RAF after each log.
I turned the LTITs off after a couple of logs and logged RAF a few more times.
I will post a bunch of Raf logs.
When i first got HP tuners and a wideband:
I changed my injector values to match the 30# SVO Red Top injectors, which was almost the right values from the "Tuner", but not quiet (According to the Spreadsheet floating around here).
I have tuned the VE table, eliminated some knock retard, tuned the VE table again, and so on. I have also been doing some MAF tuning along the way.
Tried to fix light throttle bucking by matching base and main spark advance tables under 2000 RPM at low throttle positions and blended them into the main timing table for smooth transaction. I redid my VE table again after this. Did not seem to help at all.
Also, I have a WOT run starting around frame 107060 in my most recent log,in the Recent Tunes and Logs of the zip file. I hope this helps...
Car put down 397hp and 370 tq with the tune that I logged recently.
Anyway, I have attached my Tunes, logs, and cfgs, in an organized fashion, inside a zip file. All, and any, comments welcome
Actually, here is a link to the zip file since ZIP files are not supported on this forum, right click and save as:
http://www.freewebs.com/carsontech/99TA.zip
