At first I thought it was the LC1 but I'm not so sure now. At WOT my AFR is right at 13.0 where it is commanded yet at idle and part throttle it is way lean (According to the LC1). Being that my trims are -8.6 I would think it would be rich now and the ECM is pulling 8.6% of fuel right? Well I tried to play w/ my VE tables but they really didn't affect the AFR much.
Few things I noticed:
* -8.6 trims yet reading lean in closed loop (15.8-16.3)
* Reset fuel trims, afr in 14s but as trims learn and go negative AFR gradually rises back to 16 or 17 again.
* Commanded AFR logged and says 14.63
* Turn closed loop off afr to is +/- .6 of commanded AFR
* Output from HPT, Moates meter and Logworks is the same
This is a different motor this year but I still don't think things are jiving as fuel trims are negative yet it is reading way lean. The o2s are oscillation like they should, car runs perfect at part throttle, idle and WOT. Perhaps my wideband is goofy but at WOT it is perfect. I tried a calibration on the LC1 to no avail. When I put it in closed loop and it reads lean, it is reading just from the VE tables and MAF frequency for idle fueling correct? Or am I missing something obvious here?
That is what I do not get. IF I put it into open loop AND clear fuel trims (o2s not oscillating) i'm VERY near commanded AFR, the second I put it into closed loop the fuel trims go to around -8.6 yet it goes way lean. Check out this log and check the o2 oscillation vs. wide band value. I have verified the output of the wide band using log works, my moates and the input into hpt.
I thought it was the O2s for a bit but they thought that since both banks are doing the same thing, either both are going bad at the same rate or perhaps the MAF is the culprit as it controls fueling for both sides. Ive taken the MAF out and cleaned it gently so I doubt that is the issues. What else is disabled in open loop that would skew fueling?
This obviously has something to do w/ closed loop but I'm not sure what.
Opinions?
Attached a few logs showing open loop w/ fuel trims cleared and commanded AFR Vs. actual.
