fire this off with a scanner PID query,
cam angle position, like is it possible to set it up to monitor like igntion timing?
download the latest 2.22. there are lot of new PIDs added.
I count sheep in hex...
just downloaded copy from the customer centre and been through the whole PID/sensor listing, ive noticed a few new PIDs that have been added but none for cam timing position
if this helps im running 2005 vz ute w/6spman and 175 alloytec engine with the varible intake cam.
Cheers, Bryan
the cam pids should be there, have you connected to the vehicle and did it poll the PIDs again?
scanner version is 2.22.3152.18236
and no the cam position pid isnt there
Delete your OS files in the C:\MyDocuments\HP Tuners\VCM Scanner\Vehicles. That will force a rescan of the vehicle PIDs.
Always Support Our Troops!
out of 111 supported parameters its still not showing
my vehicles OS ID is 92175390
ahh ok, i only added them to the E77 ECM's. I will add them to the older E55's this week.
Chris...
any word on 5L40!!?!?!?
Gday Chris, howd ya go with the scanner PID? not in too much of a rush as its only for conveniance
it's done, it should be in the next beta.
Originally Posted by Chris@HPTuners
is that the 5L40 or the scanner PID?
is there anyway i can make my gearbox must shift at 5500rpm,
The Scanner pid driftnpow inquired about, no ETA on the TCM in question.Originally Posted by wantmorehp
Gday Chris and Bill, wonder if theres any chance for wheel size PIDs/calculator in the speedo section.
also im just curious as to know is there more to the long term fuel trims, cause according to the scanner they dont alter as such like other OS'... how does it do its learning is it just like 5 minute overall averages, if theres more to it any chance for some pids to tweek its behaviour, cause it can be a bit of a headache with KR induced after it starts trimming.
anyway have a good weekend, cheers Bryan
I read on another thread that theres some furious work on the v6's does this apply to any of the alloytec family by any chance? if so whats to be expected or just sit tight n wait and see? cheers guys
Bryan
Gday Chris and crew, yeah wondering if the scanner can get a look in to on the latest beta, running the old E55 pcm OS 92175390, yeah been getting by for some time but yeah few PID's need a touchup Calculated Load, TPS, and ignition advance. apart from that all is sweet. cheers, Bryan
Beached as bro!
yeah this would be good. I sent Chris an PM while back regarding logging desired torque - said he would see if it was possible. No reply since to follow up PMs.....
