I have a customer with a 2007 Yukon that has a supercharger on it. The stock trans gave out and he replaced it with a TCI 4l60e. The truck drives fine but he gets a p0717 iss code. Is there a way to disable this code?
P0717 relates to your tranny's input speed sensor I would definitely investigate why its throwing this code instead of disabling it.
98 TransAm WS9 Raim Air – Stage 4 4L60E Trans -3:90 Rear -1.8 HS Rockers - Full UMI Suspension – 85MM Lid – 85MM Z06 MAF - LS6 Z06 Intake - 224/230 Comp Cam - 7.350 Push Rods - 243 TEA Stage 2 LS6 Heads 61cc - Melling 10296 Oil Pump - Caddy Race Lifters - SLP Underdrive Pulley - 160 Thermo - 42# Green Top Injectors - HPT - SLP Line lock - Pacesetter LTube Headers - Yank SS4000 - 98 to 2002 PCM Swap www.mrk-motorsports.com
The TCI trans does not have an input speed sensor in it which is why he wants it turned off.
I have been using the search function and it looks like he needs a segment swap from the stock 4l70e to the new 4l60e. I believe he currently has the 4l70e tcm on the trans, I assume he will need a tcm for a 4l60e and then the segment swap done?
The tcm/pcm looks for the input from the input shaft speed sensor.Im amazed the trans will work in the truck without a problem.
Sound like the trans shop pulled the input speed sensor or used an older 4L6x series trans when they did the build. There is *no segment swap* for the 07's since they all used transmissions with ISS.
Always Support Our Troops!
Thanks for the replies guys. I will pass this info on to my customer.
