This problem for me has been going on for months. Everyone that has looked at the car has not been able to figure out wtf is going on with my car? I have no leaks, everything on the car is pretty new, no misfires, and I just can't figure out why my car will not idle correctly in open loop mode? As SOON as the car enters closed loop (when the maf sensor takes over) the idle is perfect. The car drives perfectly fine and my LTFT are pretty darn close to 0. I still have a feeling its my VE table but before this issue the car seemed to start perfectly fine? I have tired multiple VE tables in the car and some I can't even get the car to fire over and others it idles like its running on 1 cylinder. If i even attempt to do a VE tune the more tuning I do on the worse it gets. It gets to the point where it will idle up and down so drastically the car will stall. The starting idle problem will never be the same every time I start the car. Sometimes its able to save itself by revving up pretty high then its ok. Other times it will rev down so low it stalls out. I have some videos of what the car does.
In this video you will see my car idling without the MAF sensor plugged in (open loop) then I plug it back in a (closed loop) then unplug it again. You can see that in open loop the idle is not smooth.
Engine Start Open loop- Closed Loop
This is how my car starts most of the time. It almost stalls then saves itself. In all of my videos I NEVER touch the gas petal. It rev's like that by its self.
Normally Starts
This is what my car does almost every day.
Bad Starts
This is the worst I have seen my car start. It does this once every other week. Sounds like its missing cylinders...
Worst Starts
Its just so embarrassing when I have guests or clients in my car and it does this stuff. Its getting to the point where I may need to get another car just because of this.. I am going to need some major suggestions on this guys. Does anyone have a VE table I can try with similar mods like mine? I have an HP tuner which I can import the VE table.
