Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Alloytech PCM requests
    Tuner VTuner's Avatar
    Feb 2008
    Vermont
    56
    2.8 Turbo (LP9 Alloytech) PCM requests
    Dare I ask...
    I think I know the answer to this question as I have read the posts by the solstice/gxp users, but...
    I would like to see access to torque structure tables to allow more torque to be requested from turbocharged Alloytec applications. I see the solstice/gxp users clamoring for boost control; Bosch ME9 is using a torque based structure which is governed by calculated load requests, so perhaps boost control is not really an accurate request for this application.
    Am I in the same boat as the GXP/Solstice crowd? Is it possible to crack these features given time or is it that there is a large upfront cost to purchase access to the code from Bosch, so there must be enough user demand to justify HP Tuners buying this level of access?
    Thanks!
    Last edited by VTuner; 02-26-2009 at 06:12 AM. Reason: thread 2.8T variants only please
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,292
    Given time, probably, the main problem with the alloytec style pcm is the coding in that there is no order or organization to it making actually finding whats needed VERY difficult as compared to the other pcm's we support.
    There is no purchasing done, all the cal work is done in house and is very time consuming to say the least.
    Feb 2008
    Vermont
    56
    electronic throttle valve tables
    Quote Originally Posted by VTuner
    Dare I ask...
    Thanks!
    I would also like to add ability to adjust electronic throttle position versus load at some point. Please add to the wish list!
    Feb 2008
    Vermont
    56
    Thanks for all the support so far, you guys are great!
    A few VCM Editor requests that would be most helpful:
    Boost Control (Desired Boost): As I indicated previously, this may be controlled by an internal table that is limiting maximum torque at any given RPM, but I can log Desired Boost and watch it drop quickly above 4000 rpm regardless of how much I increase Desired Air Load and Max Air Load Torque in this range.
    Displacement: If you can provide access to modify the calculated displacement volume a lot more could be accomplished (via scaling the torque model), even without access to the boost calibration tables.
    Speed Limiter (A lot of customers would like this raised or removed; BSR offers this in their tuning packages for the Aloytec 2.8T).
    Thanks again for a great product!
    HP Tuners Support
    (foff667)
    28,292
    Quote Originally Posted by VTuner View Post
    We need a scanner log of the speed limiter kicking in while logging as many spark & fuel pid's as possible so we can determine if it pulls spark or fuel & at what speed.
    We haven't been able to locate it in the code so need to know where it is so we know where to look.
    -Bill
    Feb 2008
    Vermont
    56
    OK, it takes nerves of steel to hit 155mph on the snow covered roads of Vermont, but I am willing to go to any length for you guys.
    Bill, I just sent you the scanner log you requested.
    It doesn't pull spark or fuel. The Boost DC% and Demanded Throttle % are both manipulated to regulate the top speed.
    -Bill
    HP Tuners Support
    (foff667)
    28,292
    Think dyno
    Dec 2005
    Sydney Australia
    510
    ill get you one of the speed limiter next time i have one come in..
    Feb 2008
    Vermont
    56
    Quote Originally Posted by VYSSLS1 View Post
    Already done.
    Tuner in Training lmpreza's Avatar
    Feb 2008
    Youngstown Ohio
    15
    The following sensors are not currently supported (In VCM Scanner) and I would like to add them:
    Wideband O2
    Intake Cam Timing
    Intake Pressure
    Thank-you!
    Is not Lambda the same reading as WB02, but rather in a differant format?
    At least as far as I had logged it, lambda isnt pulsing, and there are only two sensors in the exhaust stream, the Wideband, and the Narrowband (which is only for emissions check)
    I could be mistaken, but I would look into it, it seems pretty accurate to me
    More control over boost as vtuner requested would be a huge huge improvement
    HP Tuners Support
    (foff667)
    28,292
    I'll take it.
    Make sure you include its cooresponding .hpt file as well.
    Feb 2008
    Vermont
    56
    The wideband, intake cam angle, and intake pressure are all present in the latest betas, the post where I requested these features is pretty old.
    Quote Originally Posted by lmpreza View Post
    Dec 2005
    Sydney Australia
    510
    I'll take it.
    no worried bill give me a couple of hours and ill email it too you
    Dale
    Feb 2008
    Vermont
    56
    I'll take it.
    Bill,
    I just PM'd you two .hpt files for your reviewing pleasure.
    Dec 2005
    Sydney Australia
    510
    did you send him the log to go with it?
    Dec 2005
    Sydney Australia
    510
    I'll take it.
    bill,
    email sent
    Feb 2008
    Vermont
    56
    Yes, yesterday. Just curious, which version of the alloytec are you logging and providing the .hpt file for? I am sending the 2.8T (184kW) files from a 2007 Saab Aero.
    VTuner
    Dec 2005
    Sydney Australia
    510
    2005 VZ Holden Commodore, 3.6L non turbo very non performance engine
    Dec 2007
    776
    As my Japanese friends would say: this sounds like "noodle" code.
    Tuner driftnpow's Avatar
    Feb 2008
    South West WA
    151
    Bosch to thank for this family of labyrinth pcms :P
    we have a saying in AU, "sh*& from ar^*hole to breakfast time"
    that said ive had some fun with my ride - ute with 175 KW block, 6 sp manual.
    one of the bigger turning points tuningwise was when the PIDs that let you alter "max ve" and "desired airload" were added, by jeeze it helped to breathe life into the engine response, - thanks again guys!
