Results 1 to 9 of 9
Thread: 6T70 options?
    Apr 2006
    Twin Cities, MN
    139
    Question 6T70 options?
    Just wondering what tuning options HPT's got available for the 6-speed 6T70 transmission found in the 3.6L v6 configurations that GM's put out for the G6, Aura, Malibu, LaCrosse, CTS, STS, etc
    The Aura, I know, is paired w/ the E67 ecm in these configurations for the 2007 MY
    Thanks!
    The '07 Aura XR
    [In] XM ExpressEZ
    [Next] intake res delete, Tint, Eibachs
    The Procharged Ion - SMP Stage 2 QC
    20/5 tint, SPS stb, CF dash, reflective bumper insert, 62mm TB, RL plugs, masked corners, progress rsb, RL fsb, 2.5" cat-back, triple pod w/ Boost, FPG, LC-1 & XD-16, filled front & rear mounts, pclear shorty shift, Procharged, Eibach Pros, 8k HIDs - 188.28whp / 175.03wtq, NO TUNE
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    http://www.clubgp.com/newforum/tm.as...mode=1&smode=1
    These screenshots should give you an idea.
    Apr 2006
    Twin Cities, MN
    139
    Quote Originally Posted by Bill@HPTuners
    perfect thanks.
    is there anything to worry about when adjusting the shift speed parameters? ie: is it possible to command a shift that's quicker than what the mechanics are able to do, and cause damage?
    The '07 Aura XR
    [In] XM ExpressEZ
    HP Tuners Support
    (foff667)
    28,268
    unless you somehow switch the upshift & downshift speed/rpm you shouldn't run into many issues.
    Apr 2006
    Twin Cities, MN
    139
    i think i'm getting confused w/ what "shift speed" means...
    does it mean the time taken to shift from gear to gear, or the speed the vehicle is traveling when the shift is made?
    The '07 Aura XR
    [In] XM ExpressEZ
    HP Tuners Support
    (foff667)
    28,268
    In the case of those screenshots its what speed & rpm the vehicle is at when the shift is made.
    Apr 2006
    Twin Cities, MN
    139
    bummer.
    is there anything HPT can do to alter what i'm referring to? the time it takes for an auto trans to perform a shift?
    The '07 Aura XR
    [In] XM ExpressEZ
    Apr 2006
    Twin Cities, MN
    139
    :bump:
    The '07 Aura XR
    [In] XM ExpressEZ
    HP Tuners Support
    (foff667)
    28,268
    You'll be able to delete TM, adjust shift pressure, etc but these new transmissions & controllers aren't simplistic like the older pcm controlled transmissions. Im pretty sure we're the only software to even offer tuning for those TCM controllers currently.
    -Bill
