I have been tuning on my C5 using SD. Everything is great until i try to go above 17lbs of boost. At that point i get a reduced Engine power at about 4800rpm. It sets the 1514 code. I have maxed out the table to 4.1 across the board, and even tried deleting the code.
When i deleted the code, it still went to reduced power, just didn't show the code anymore, but i am sure it would be the same. Is it possible i am going above the 4.1?
What would i need to log to check that, and how do i fix it?
thanks
