Results 1 to 20 of 39
Thread: Disabling LTFT for good??
    Mar 2007
    St.Charles, IL
    81
    I just started tuning a 1999 camarow ss that has been tuned prior to me. The reason for the re tune is that we just put heads and a cam in the car. I opened the tune and i noticed that the LTFT had been disabled. My question is, what would be the reason for doing this i understand that the LTFT are percentages of STFT and that they are a stored value the the PCM references back to so i guess i could kind of see why you would do this but does it really help you in any way. The one thing that i am seeing is that with the LTFT off my STFT are way out of wack like -15 but when i enable them STFT seam to go down a bit.
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    STFT will go down with LTFT on because the LTFT is going to pull that fuel. STFT should be around zero after enough learn time. Main reason I like LTFT off on my own car (when it was closed loop) is to prevent false + fuel trims at WOT, adding too much fuel.
    Sulski Performance Tuning
    Aug 2009
    Calibrating
    3,377
    Is the general consenses to disable LTFT's still? I have NGK wideband for my Blower setup to tune and I think I will disable the LTFT's to dial in the STFT's and never turn the LTFT's back on. Is that acceptable?
    Car is a MAF sensor setup if that even matters?
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    Feb 2008
    665
    Should be just fine, alot of people just run STFTs only.
    2017 Silverado LTZ
    Advanced Tuner robbyredneck's Avatar
    Jan 2010
    fingerlakes ny
    356
    +2 i am currently running only my st's and thinking about going full time open loop.
    04 6.0 silvy china turbo
    87 gn
    03 stroker evo ww
    00 ss camaro
    Nov 2005
    Houston, TX
    3,968
    I have had LTFTs disabled for years now. STFTs only.
    Bill Winters
    Out of the LSx tuning game
    Aug 2009
    Calibrating
    3,377
    Ok guys thanks, seems like there isn't any downsides to keeping it enabled really. Plus from my understanding STFT's learn very quickly and are generally easier to tune than LTFT's anyways??
    14 Gen 5 Viper
    Nov 2005
    Houston, TX
    3,968
    Thats my take on it. The benefit is positive STFTs do not add to PE like positive LTFTs do.
    Bill Winters
    Tuner copley87blazer's Avatar
    Mar 2011
    Wilder,ky
    131
    When you use both stft and ltft toghther dont they take an average and use that???
    Aug 2009
    Calibrating
    3,377
    I am pretty sure that the ECU takes the data from the STFT's and then averages it into LTFT's (my understanding)
    Also seems like a MAF-STFT histogram may seem the best way to tune too (Fast and efficient) Anyone want to share theres?
    14 Gen 5 Viper
    Nov 2005
    Houston, TX
    3,968
    It works like this: STFTs make quick adjustments to fueling. If a fuel trim cell's STFT stays at a certain number for a certain amount of cycles, that becomes the LTFT and the STFT is reset to zero. So LTFT is 0, STFT is +5 for x samples. LTFT becomes +5 and STFT resets to zero. After a while STFT stays at +3 for x samples then LTFT becomes +8 and STFT becomes 0.
    Bill Winters
    Jan 2010
    fingerlakes ny
    356
    and then when you go wot it stays fat or lean. kind of diffusing tuning your open loop for wot and especially boost. thats the importance of getting your lower range ve in check or turning off your ltft's
    87 gn
    03 stroker evo ww
    00 ss camaro
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    I will not go lean at WOT because of LTFT, only adds fuel. PE + LTFT additional fuel.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Jan 2010
    fingerlakes ny
    356
    thanks bird, i stand corrected.
    87 gn
    03 stroker evo ww
    00 ss camaro
    Dec 2008
    on the Dyno
    1,825
    I disable LTFT on everything I tune! Most stuff I make run open loop as well cause the customer doesnt want to buy good o2 sensor's @ $50-60 each to make it run correctly. I had bad o2's in my car and did the same and if tuned properly will not suffer any. I still averaged ~26mpg on a trip to Florida with a G5X3 6.0L LQ4 5.3 headed in my 98 TA.
    Located in Central Kentucky
    ShorTuning
    Jan 2010
    fingerlakes ny
    356
    just this week i tested out full time open loop. bye bye o2 sensors. i get lean cruise and lean idle with so far no detriment. ambient temps have gone from 50-90 here in upstate and the car has responded fine.
    87 gn
    03 stroker evo ww
    00 ss camaro
    Aug 2009
    Calibrating
    3,377
    So from the factory GM uses Closed loop MAF (CLMAF) and disabling the LTFT's permanatly makes is open loop MAF (OLMAF)?
    14 Gen 5 Viper
    Nov 2005
    Houston, TX
    3,968
    No. Disabling LTFTs leaves only STFTs to do the closed loop function. Disabling LTFT and STFT puts you in open loop.
    Bill Winters
    Sep 2009
    346
    From factory: would be using a VE / MAF blend as well.
    Sep 2009
    346
    Quote Originally Posted by 5_Liter_Eater View Post
    Bill, Running STFTs only (CL) is your recommendation especially for blown applications?
    Im going to guess, UNLESS your lower VE (if you were running SD) was dialed in... then the LTFTs would not have much effect on PE.
