Logs? Just about every drive for the last two months... What would you like to see?Originally Posted by Dirty Howie
As to whether or not the cap is truly needed depends upon the design of the ecm itself. I don't have a spare to disassemble (anybody got a junker?), but I'd be very surprised to find that GM doesn't have filtering of some sort on it's inputs. The question is how much and how designed? There's the possibility that somebody figured that since the egr position doesn't need a high degree of accuracy that they could shave a few pennies on the filtering there.
I look at it this way. Treat the ecm as a high impedance black box (worst case). In this instance, the wire from the controller resembles an antenna as much as anything. A small capacitor placed across that antenna is going to shunt a lot of the picked-up noise straight to ground, no matter what filtering the ecm itself has. At the same time, the input signal changes slowly enough that the capacitor will have no effect on on the desired signal.
PLX's description of what happens to the voltage matches what we see, as far as it goes - but sheesh! We could just about get that from the docs!
