Originally Posted by
engineermike
Im assuming you mean max load, not just load in general which is always changing. At any rate, if you lower compression to, say, 9/1 then MBT will be much higher. If the MBT in the table isn't accurate to the engine characteristics, then torque reduction ratio will not be accurate, which can lead to problems just like the ones the OP is experiencing. I've seen this also cause idle stability problems when tuners raise MBT such that it no longer matches the engines physical characteristic.
If the MBT number no longer matches the engines actual MBT, then I suppose you could fix it by making the torque tables inaccurate as well. I would just rather both be as accurate as possible and not just one error offsetting another.
