Thread: 2014 3.2l Ranger sid208 - Hardcut limiter (popcorn) help?
    Apr 2024
    Question 2014 3.2l Ranger sid208 - Hardcut limiter (popcorn) help?
    I've been trying to figure out how to add a hard cut limiter to a ranger tried adjusting the desired torque @ all throttle positions @ 4000rm normal then 4005rpm 0 torque but revved right past it.
    Many places around me offer it so that is obviously a way.
    I was looking at the torque limits and the tables seem to only be used under full load and not sure if that they would be under use when stationary.
    I've attached my current tune & stock incase anyone needs a stock tune for a ranger or would like to have a play around as well as a picture of {Torque Management>General}.
    2014_Ranger3.2L_Auto.hpt
    2014_Ranger3.2L_Auto_Stock.hpt
    Any help is really appreciated.
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    479
    Quote Originally Posted by darcypastie View Post
    It might have to be done in binary? HPtuners might not have the table defined.
    BUT. Hard cuts normally cut the fuel injector at the specified RPM and then there is a resume function.
    The cut and resume would have to be pretty close to each other to get it to bounce(if that?s what your trying to do)
    Apr 2024
    Yeah thanks for the reply, might have to look into other software
    Jun 2012
    warrenton va
    479
    This is where user defined parameters will help IF the tables are there in your OS.
    I have seen in the past ford and Chevy will add parameters to new OS?s and even take them away because they aren?t needed
