Ok, I went through all of the connections and was able to get it to work. I followed the instructions in the manual and did the free air calibration and was working good, the o2 was reading 20.x AFR in free air. I got my pid's working in HP Tuners. I disconnected it and heat shrank plastic over all of the connections. Then connected the unit again to verify and now I get an Error 9 (Supply Voltage too low). So I took the plastic off checked and re-checked the wiring and all is good yet the error is still there. I checked with a voltage meter and it seems that there is good power. I'll try another meter and try this out again tomorrow. I though I was out of the wood but no such luck yet.
