Results 1 to 8 of 8
Thread: 2015 Challenger 5.7 TSP BFD Cam, VVT locked, Valve Springs, MDS Delete need help
    Hello Everyone,
    I am new to tuning this new-fangled electronic stuff. I had a head gasket leak in cylinder 7 so why not just upgrade right? I installed the TSP BFD cam, new valve springs matched to the cam, MDS delete, scat pack airbox, otherwise the rest is normal. It is the automatic, I have not done a torque converter yet. I have turned off the NN and went with the VE tables. I have played around with the tune, and went through the tables as I have seen suggested. When I put the car in drive sometimes it goes fine then other times it just stalls. When I do have it where I can drive it, the car will suddenly stall when turning into the driveway or a turn. I am including the scanner results and the tune with this. I hope someone can help me get this figured out.
    challenger.hpt
    24-03-25 11-04-34.hpl
    Thank you everyone, I really appreciate any help.
    Thank you,
    Jeremy
    Stock Tune
    This is the stock tune
    lewis2015challengernew.hpt
    Jun 2021
    20
    try this and you need to log air-charge and pressure ratio and dial in your VE and get a wideband to tune WOT
    Quote Originally Posted by JohnnyFW View Post
    Thank you, I will give it a try and log those. I was figuring I needed a wideband, just have to get one ordered.
    Thank you again,
    Jeremy
    5BA8
    3,463
    I wouldn't worry about a wideband until you get it running right at part throttle.
    email=[email protected]
    5BA8
    3,463
    A VE table should never be higher at 600 RPM than it is at 800 or 1000 RPM.
    This is more like what it should look like.
    Jun 2021
    20
    yes i agree on the wide band and i know VE should not look like that i just smooth the base VE map out a bit that is why i said he should dial it in im pretty new in tuning so dont have VE tables that would be close, so i help with what i can
    Nov 2019
    Bahrain
    77
    Dial in your VE at idle,
    I've dropped it by 20 for the car am working on now which is running BTR stage 2 VVT cam.
    Go to the torque model and then to friction loss table and bump up the figure to 5 as a start up where the rpm drops,, like from 600-1000 rpm where the car struggles usually.
