So I have a 07 silverado classic at WOT it does not go into pe or the correct eq ratio. I've set tps enable as low as 40% no delay enrichment rate to 1.5 , all enable stuff is satisfied. BUT pedal position goes all the way to 165%. We have swapped pedals, tac module, and ECU. Even swapped to an 05 ecu and Tac and read the same 165. Tps hits 99.6 around 66% pedal position. Is this normal. I do lots of gen 3 trucks and never seen this before. I'm surprised there's no reduced engine power. Part throttle you don't notice any issues, it drive great. But WOT It commands 14.68 and "Closed loop normal".posting from my phone so I can't post files.
