Page 2 of 8 FirstFirst 123456 ... LastLast
Results 21 to 40 of 153
Thread: Looking for some help/advice on E38 Idle
  1. #21
    Aug 2006
    5BA8
    3,446
    Quote Originally Posted by Allen Vos View Post
    Ok great, so now looking at my logs I can see the idle is likely what is causing the swing in spark correction causing my idle oscillation's.
    It is the over active throttle blade that is causing most of the RPM oscillations. I blew up both line graphs so you can see it better.
    You have to undo your prop table settings, make your spark tables a little more aggressive, and get the VVE dialed in so you're not idling in a ditch.
    You need to lessen the throttle movement so your spark isn't chasing it around. Not sure how many different ways I can say it.
    EFI specialist
    email=[email protected]
  2. #22
    Jul 2020
    VIC Australia
    1,180
    You don't need a wideband to get the majority of your tuning done, and most importantly, all of the start-up and idle tuning.
    Your VVE needs to look like it makes sense. You can't idle in a steep valley where every time you move out of that valley you move into a much higher cell whether you go up or down both in RPM and/or MAP.
    You need to put the majority of the calibration back to stock and concentrate on getting your most basic tables straight. By doing so you'll need to change far less other random tables like idle PIDs.
    That's the best advice you'll ever get. kiss
  3. #23
    Aug 2006
    5BA8
    3,446
    1) how come the idle oscillates while its warming up and once it warms up the idle is rock solid?
    There's so much wrong in the calibration there's no single answer for this. It is a combination of several things.
    2) I have only set the idle on the VVE table. It initially needed to be cut back almost 40% in some areas so that's why the valleys. Yes I know its a bit of a mess but what would be the
    easiest way to straighten things out "Just" to get it idling better?
    There's no easy way to answer this other than it needs to have a certain shape. It needs to be lower in the lower RPM columns and lower in the lower MAP rows.
    I would prefer to stay a MAF and Speed density table combined as opposed to straight Speed density.
    Yes I know speed density may be simpler but I really want to learn how to tune them both.
    It's not that SD is easier, it's that it runs better in these cars C6 Z06s. The main reason is the MAF is right in front of the throttle body and with a lopey cam the maf responds to the reversion. You can watch it happen in the scanner. The maf flickers or twitches and it adds to the trailer hitch effect. In speed density it completely eliminates that.
    EFI specialist
  4. #24
    Jan 2023
    254
    I read you loud and clear. I was just trying to understand why it was doing what it was doing.
    Initially I had thought the Oscillations in VVE were because of the oscillation's in the Spark which changed RPM which changed the MAP values causing it to run on a different spot in the VVE table.
    But its looking like based on what you are saying its the VVE table causing the swings in RPM along with the spark tables.
    I ask all these questions because I am trying to understand all this and make sense of it.
    What I was trying to ask you is , what is the best way to smooth the VVE table?
    I have already gone in and made changes to bring the VVE numbers down as they were 40 % higher.
    So am I best to go in and just smooth things out manually around the idle numbers to fix this?
    How would you go about fixing the VVE table?
  5. #25
    Aug 2006
    5BA8
    3,446
    Interpolate and smoothing.
    This is your VVE with a few button clicks.
    That's all I changed. Good luck with it. Like I said many times I'd undo a bunch of what you've done and just concentrate on tuning it strictly in speed density.
    TSP Stage 2 Camshaft with CTS idle proportional and intergral table with MAF plus VVE changed_E.hpt
    EFI specialist
  6. #26
    Aug 2010
    Detroit, MI
    947
    I bet that VE fixes almost all of the issue by itself.
  7. #27
    Jan 2023
    254
    Thank you for being patient with me. I was used to tuning on an older system called Mega Squirt which was a very very simple setup on speed density.
    I am a slow learner when it comes to this stuff as I try to be very through and try to understand why things get changed the way they do.
    But I do understand things completely once they sink in. lol
    Thank you kindly for your help, I will try this out later next week when I get back to the car and report back.
  8. #28
    Mar 2009
    Andover, MN
    499
    I wish there was more of a half ass explanation on how to tackle Prop vs Integral for idle swings. I know people say stock are fine. Well there are quite a difference between say a 5.3 and an ls7 lol. So far softening Prop as little bit seemed to help, but then I added integral to quicken up the idle oscillation. Seems better overall but it still has a surging. I will be curious what the OP will post once his VE is dialed in.
  9. #29
    Aug 2006
    5BA8
    3,446
    Quote Originally Posted by ns158sl View Post
    It all depends on when it surges as to what needs changed to eliminate or lessen it. Like I've said here ad nauseum I very rarely touch the PIDs. I want the least amount of over/under correction in the blade. I definitely don't want to increase the movement.
    EFI specialist
  10. #30
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    551
    Jerry Seinfeld had a joke about people going into those big box stores and buying loads of toilet paper (this was well before COVID was a thing) and observed that these people are tackling the problem from the wrong end. This is the same thing in regards to attempting to fix idle issues using the idle air PIDs.
    I assert that about 90% of throttle control SHOULD BE done with proper min final airflow and base idle advance.
    And about 9% of idle control should be the over/under spark correction.
    The remaining 1% will be done with the idle air PID controls, and this should be the lightest touch.
    << I am making these percentages up, they are not scientific, but just trying to demonstrate the relative importance >>
    This means that if you are attempting to fix idle issues with the idle air PIDs, you are tackling idle from the wrong end. You in fact never want the ECM to have to resort to using the idle air PIDs if at all possible. They are a last ditch effort to control idle RPM.
    A standard approach will give you standard results.
    My Tuning Software:
    VVE Assistant [update for v1.5]
    MAF Assistant
    EOIT Assistant
  11. #31
    Aug 2006
    5BA8
    3,446
    Quote Originally Posted by Cringer View Post
    You in fact never want the ECM to have to resort to using the idle air PIDs if at all possible. They are a last ditch effort to control idle RPM since air.
    This right here.
    EFI specialist
  12. #32
    Nov 2006
    2,853
    Even in that situation the stock stuff is fine.
    Before getting too deep into any idle tuning the fueling needs to be as close as possible. If its got a decent cam in it, it should be done in SD first. It's not that SD is easier. I'd argue it's harder. It's that a MAF sensor reads cam reversion so it sorta double dips reading airflow.
    I agree with whoever said something along the lines.. "best to go back to mostly stock and only fix the most basic tables first" Everything else will likely fall right in line just by doing that.
    Tuner at PCMofnc.com
  13. #33
    Mar 2009
    Andover, MN
    499
    Virtual torque also affects idle. Obviously without an engine dyno a guy is pretty much adjusting it blindly. I still think a chassis dyno with an arbitrary multiplier for parasitic loads and drivetrain loss would be better than leaving the VTT stock.
  14. #34
    Aug 2010
    Detroit, MI
    947
    Guess it'll just remain a mystery why idle airflow control exists at all
  15. #35
    Mar 2009
    Andover, MN
    499
    Quote Originally Posted by smokeshow View Post
    You wouldn't understand, just crack the throttle blade open further, duh. Lmao.
    I am guilty, along with others, of what Alvin keeps iterating of getting fueling spot on before going about turning all the knobs.
  16. #36
    Tuning Addict
    Jan 2015
    6,855
    Guess I go against the grain on this. Yes airflow and fueling need to be dialed in. There's no discussion there, but I also believe in adjusting the other players as well. Manuals for example have a lot of "clutching" gains in the proportional table. Even very light throttle driving can be affected by it. The integral table is actually what controls idle spark corrections, so I don't understand how you can say you want as little correction as possible while relying on spark? They actually both control spark whereas proportional primarily controls throttle or your immediate "big" corrections.
    Don't know, I just prefer to optimize all that I have. I agree at a "rest with no loads much" I like to have very little plate movement, but there's still other aspects to idle than just "at rest with no loads".
    ~Greg Huggins~
  17. #37
    Aug 2010
    Detroit, MI
    947
  18. #38
    Aug 2006
    5BA8
    3,446
    The gist of the thread seemed to be at rest idle stability. That's what all of my comments have been based on. Further, if we're talking about anything other than at rest idle, we're not really talking about idle stability are we? We're talking about off-idle, return to idle, etc. If we're expanding our conversation into these other off topic, off idle subjects, I still very rarely use PIDs. There are other tables for those situations.
    EFI specialist
  19. #39
    Aug 2010
    Detroit, MI
    947
    The idea I was trying to get across was compensation for external loads. They're what we call 'idle cramping' scenarios in Detroit. From an otherwise steady idle, load up the engine with garage shifts, AC, cranking the wheel, loading down the alternator with power windows rolling up, etc. Enough load and you'll run out of spark to make a correction...that's one place where the idle airflow control really comes in handy.
  20. #40
    Aug 2006
    5BA8
    3,446
    All of those scenarios have individual tables to help in each individual situation, without having to touch the PIDs. Trans shit transition tables, AC load torque tables, etc. I feel it's more accurate to address each scenario with the corresponding table rather than affecting the overall over/under actuation of the blade.
    EFI specialist
