Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: Trying to do some tuning and can't seem to go into any boost at all.
    Nov 2015
    Albuquerque NM
    31
    Spent all day setting this up and can't seem to go into any boost whatsoever just wondering if there's a setting that's off. If you guys can take a look and help me out, I would appreciate it and thank you.
    Aug 2006
    5BA8
    3,253
    Looks like something is wrong with the throttle body/blade, etc. How about describing what the build is? Vehicle, swapped, mods, etc. Would make it a little easier instead of guessing.
    I'd bet if it's an aftermarket throttle body you have the cable in the wrong hole.
    Is this a DBC from the factory? I thought this vehicle was DBW?
    EFI specialist
    email=[email protected]
    Nov 2015
    Albuquerque NM
    31
    Well this is a p59 swap into 2003 chevy Silverado LQ4 408 DBC now, Procharged F1A-94, 102mm tb.
    It rev normal in park and will rev to over 5k. but while driving is where the issue comes where seem to lose power if you try to push the pedal to half way, but only when in drive.
    Aug 2006
    5BA8
    3,253
    In park there's no load on it. Reving to 5 grand doesn't mean anything.
    Have someone sit in the driver's seat and put the throttle pedal on the floor. Engine not running of course. Then try and open the throttle blade more with your hand. I'll bet your throttle cable is in the wrong slot of that 102 TB. Happens all the time.
    EFI specialist
    Nov 2006
    2,742
    Quote Originally Posted by Flewbyu123 View Post
    I don't see anywhere in the log where you tried to give it much throttle at all. Did you post the wrong log?
    Tuner at PCMofnc.com
    Nov 2015
    Albuquerque NM
    31
    will take another look but did that when I put it on had my wife push it to the floor then adjusted my cable
    Nov 2015
    Albuquerque NM
    31
    yes while on the short drive, only a small press or big one there seem no real change other then the more I press the less it responded
    Aug 2006
    5BA8
    3,253
    It never even goes to half throttle.
    EFI specialist
    Nov 2006
    2,742
    Yep.. I wonder if he has a cable setup issue. Verify the throttle body is opening all the way
    Aug 2006
    5BA8
    3,253
    That's what I've said multiple times.
    EFI specialist
    Nov 2015
    Albuquerque NM
    31
    Well. Thanks got it figured out.. Its was tune related..
    Nov 2015
    Albuquerque NM
    31
    Mar 2022
    Indiana
    2,948
    What was it?
    Nov 2015
    Albuquerque NM
    31
    What was it?
    It was thinking it was on like E50 and some timing issues.. But it was only on pump gas.
    Mar 2022
    Indiana
    2,948
    How did you achieve 100% throttle opening though?
    Aug 2006
    5BA8
    3,253
    I'm sure it was. It's the only DBC tune that kept itself from going over 50% throttle.
    EFI specialist
    Aug 2006
    5BA8
    3,253
    Wow you must really think we're REALLY dumb.
    EFI specialist
    Nov 2015
    Albuquerque NM
    31
    its was in the tune. its better not 100% on the tune. but I can open the throttle a 100% had me bed filled with over 1000 pounds to help with the tuning. And I also still have some belt slip as well.
    Nov 2015
    Albuquerque NM
    31
    LOL, guest there stuff you still not knowing.. But look at my posted tune and see if you can spot it! if you're able too. I will tomorrow post my new tune.. then you tell me if you are dumb or not.. I'm not a good tuner which is why I ask for help! this is what I was lead to believe, and thought what was going on!
    Aug 2006
    5BA8
    3,253
    There's nothing "in the tune" that will keep a cable throttle body from going wide open.
    EFI specialist
