Results 1 to 8 of 8
Thread: cammed 6.0 idle in gear issues
    Oct 2021
    8
    cammed 6.2 idle in gear issues
    Cammed 6.2 in a jeep jku. Often when shifting from drive to reverse it stalls. Or if you rev it on decel and put it into gear it stalls. Have played with minimum idle airflow for 1st gear and reverse with no luck. adaptive spark up and down, no change. Can't figure out what I'm missing. Log and tune attached Thanks!
    Aug 2006
    5BA8
    3,254
    Complete list of mods, please and thank you.
    EFI specialist
    email=[email protected]
    Oct 2021
    8
    Customer jeep. Bought it built. No info other than believe its a l92. 5364 heads, stock gen 4 truck intake, healthy sounding cam, long tubes and free flowing intake. 6l80e attached to it.
    Aug 2006
    5BA8
    3,254
    There's no tune file attached only 2 data logs.
    EFI specialist
    Oct 2021
    8
    Fixed. Sorry still new to this
    Aug 2006
    5BA8
    3,254
    First off you have WAY TOO MUCH idle timing in it. Should be 16-18 degrees even with a larger cam. Next thing is you need to dial in the VVE. You can't just run it in "MAF mode" and expect it to run right.
    Didn't look past that. Could be way more wrong.
    EFI specialist
    Oct 2021
    8
    Copy that. Thanks, like I said new to this. Didn't even notice dynamic airflow was disabled. Again, working off of someone else's tune. Runs and drives great otherwise.
    Aug 2006
    5BA8
    3,254
    Quote Originally Posted by evolutionauto View Post
    Unfortunately the GEN4 PCMs are incredibly forgiving. They can make crappy tooners look qualified. I see a lot of really bad stuff run half decent.
    EFI specialist
