Results 1 to 13 of 13
Thread: L5p reading and writing.
    Tuner djv86's Avatar
    Aug 2023
    PNW
    74
    assuming one has all the proper hardware and cables to unlock and read a file from a l5p was is the oldest software verison of VCM editor that can properly read and write to that ecm ?
    07 classic
    Aug 2023
    canada
    50
    no your going to need newer version of hpt.
    Aug 2023
    PNW
    74
    can the l5p be bench upgraded ? i see the upgrade tool connects to ecm fuse. so if that fuse was connected to a 12v the also cooperates with the bench tuning setup for switched ign voltage would that work ? or does it have to be installed in a vehicle ?
    07 classic
    Aug 2023
    canada
    50
    you can purchase this to unlock your l5p without shipping it in.
    https://powerstrokecustoms.com/produ...m-upgrade-kit/
    Aug 2023
    PNW
    74
    Quote Originally Posted by dieselpitstop View Post
    I already own that. i also have a bench tuning setup for the lb7s. i was wondering if i had the right connectors to plugs the l5p ecm to the benchtop setup if i could perform the upgrade on the bench. and just figure out how to simulate the fused power that the upgrade tool connects to in the fuse box
    07 classic
    Aug 2023
    canada
    50
    are you using benchforce?
    Aug 2023
    PNW
    74
    I Have their original one yes. i know ill have to upgrade it to the newer ones which are now benchforce. but was just more curious if its possible. i have a friend who has a l5p ecm and was curious if its possible or if it must be installed in a vehicle.
    07 classic
    Aug 2023
    canada
    50
    YES its is possible.
    Aug 2023
    PNW
    74
    what would i do with the two wires from the fuse ? im guessing the upgrade device uses one as a 12v input then makes the own pcm turn on voltage with the second wire.
    07 classic
    Aug 2023
    PNW
    74
    can the e41 upgrade ONLY be done with the vcm suite beta ? or can it be done with the latest stable version of vcm suite ?
    07 classic
    Apr 2021
    38
    It can be done with the latest version of VCM Editor
    Aug 2023
    PNW
    74
    Quote Originally Posted by slimmons2009 View Post
    does it have the be the beta version ? or the stable one ?
    07 classic
    Apr 2021
    38
    It can be the stable version
