Check to see that your have the latest version of VCM scanner. You can get some weird readings from an older version or try beta. The one time that I saw you get into power enrichment briefly you had .64 lambda on the right and .82 on the left. Also your IATs are hot for 64 degree ambient temp. I would expect them to drop alot on your highway drive. Check to see that you are circulating coolant in your intercooler. When you took off from 0 mph it looked normal. Timing increased and it stayed right at 1.00 lambda. Any codes? If the truck has not been modified from the way it came from the dealer, I would look into a mechanical problem. Most likely not tune related.
I'm on version 5.0.4
It reports, "No update found".
I tried going WOT several times throughout the course of this ~20 minute datalog. Almost every time I went WOT, the engine would feel like it hit a limiter/lose power/not accelerate. This coincides with the data showing 0's and negative values. If I tried "aggressive" part throttle instead of WOP/WOT, the truck would pull for a bit.
As for the IAT's sure, I can check that when the truck comes back but, the recorded IAT's are not high enough to create the symptoms/lack of power that I notice.
When it showed up it had P0420, P0430, and a P0300 stored--a couple of catalytic converter efficiency codes and a random misfire code. I pulled a spark plug and found that the previous shop, a Ford dealer, had installed stock F-150 replacement spark plugs with stock gap. I replaced them with LTR7IX-11's gapped at 0.032" and cleared the codes. In the course of my troubleshooting and test drives the codes did not come back.
From what I can tell, this truck is unmodified from the way it came from the dealer.
