Results 1 to 3 of 3
Thread: 2011 GMC Sierra 5.3 - Truck Norris Tuning
    Jan 2023
    1
    Hi,
    New to tuning. I was hoping to get some tuning help on my 2011 GMC, its a 5.3 with a Truck Norris cam, long tube headers and a Fast LSXRT intake.
    - on start up it seems to overshoot to ~2k rpm
    - any time the throttle is blipped it wants to die when returning to idle
    If anyone has any input it would be greatly appreciated!
    Tune and log file are attached.
    Jan 2021
    7
    I was hoping someone would reply to this as I have the same cam. 08 H3 Hummer with a 2019 6.0, with Truck Norris Cam. E67 pcm. Your scan looks exactly like mine. I can get the SD/Maff tune good, it's the Idle that is kicking my ass. I used this thread and it did NOT work for me. It's like it doesn't respond to timing and every time you adjust, the AF ratio goes to hell. https://forum.hptuners.com/showthrea...&highlight=e67
    Same cam here.
    07 5.3 alum block LC9
    Mine doesn't want to fire at all. I think it's a timing issue but may be Airflow. I just came to compare.
    Can you share a file @ricmin?
    I'm a newbie too, but I feel like I have a handle on adjustments. Did not expect trouble with initial startup.
    P.S. Sure wish I could just turn the distributor.
