Noob here.
Short story: I E-Force supercharged my NA pro-tuned LS1, did the 2 bar OS upgrade, modded HPT per this vid: no start - it sometimes kicks off but dies, then just cranks until I power off and try again.
I'm seeing very strange things in VCM Scanner. Is it me?
3 log files attached. MAP sensor voltage is ALWAYS .80V, but sometimes reads 0 kPa, sometimes 20, sometimes 40. 40 seems correct based on voltage curve for my sensor, so wondering if MAP sensor is bad. Note that I added 2 bar MAP channel in the 2nd and 3rd logs.
23-11-18 10-46-40.hpl
23-11-18 10-48-08.hpl
23-11-18 10-49-50.hpl
This is the log of the first start - check out all the sensors counting up even though the car is just sitting there with ignition on... Hasn't done that since.
23-11-12 11-23-31.hpl
HPT in case that's needed - not asking for full diagnosis yet, which I know will require more details from me:
2023-11-10 LT-2barOS-1stMods.hpt
