GM LQ9 swapped into my 2004 Tahoe about 18 months ago, original PCM sent in to the builder and he told me he put a 6.0 Escalade tune on it.
Lately has been going into 'limp mode' i.e., "reduced engine power". Have to pull over, let it sit turned off a minute or two and it'll start back up and run another few minutes (sometimes) or few seconds. Had this problem 6 months ago, a local shop told me it was the throttle body and throttle body control module. They replaced both ($900) and it worked since. Now it has started again, and worse.
New shop says they have traced wiring and when plugging the computer back in, it trips the circuit for the wiring to the throttle body, even with power off. So... they say they are fairly sure it is something physical in the computer causing a short. So I need a new PCM.
Can't just buy one off Ebay, because I have the 6.0 tune, so they won't program it for a 6.0, only my stock 5.3.
I have an HP Tuners MPVI2+ with 2 credits. I purchased this 18 months or so ago, never used it. Can I just buy a PCM off Ebay (or somewhere) and download the stock Suburban 6.0 tune I see in the repository, load it onto the new PCM and plug it into my truck? Then deal with 'tuning' issues like turning on my fans and such later?
I don't really know how this works too well. I just need to try to get my truck RUNNING, then I can work on tweaking.
I have an external wiring harness I bought, as well, so I can program outside the vehicle.
