07 Crown Victoria
New here learning the ropes. If anyone could help me figure out some adjustments added a few parts and need to see what I need to adjust for a bigger bbk throttle body and a 340lph fuel pump. Have more modes but that's more or less where Im starting the adjustments. Saw there was a setting to change voltage for fuel pump. Can I adjust that and not have to do a fuel pump rewire or BAP?
Mods to the car.
Edelbrock Victor Jr intake manifold mmr plenum adapter
Stock plenum
Bbk 80mm throttle body
Bbk shorty equal length headers
Dual xpipe setup
1/2" spacers on the plenum and throttle body
Have a few other parts pending. Depending on how the tuning goes
went ahead and just started from scratch decided to tune the intake manifold. I did some logs changing the manifold volume a few time to see how it did
first log is oem stock file oem is 9.2l
second is 7.0 liter
third is 6.0l
fourth is 10l
oemlog.hpl
mod1log.hpl
modvol6.hpl
mod10lv.hpl
oem file
2007oemfile.hpt
Some crown victorias have a map sensor on the egr module so haven't made a egr tube yet so reason for no readings on logs and why I'm getting a high manifold pressure code. Just little update
alright so got the egr worked out readings are a little better than before idles alot better. heres an idle log along with a pull or two and little cruise oemlog2.hpl
havent gotten much help but if someone could be helpful and help me with this bbk throttle body i installed per the instructions but getting a actuator stuck closed code . noticed on idle with the oem throttle tps was sitting at 4.25 with bbk 4.33 at idle heres a log with bbk throttle body it went in limp mode had to turn off then back on to get homebbktber.hpl
i think i got a good base line for it didnt give me a check engine light yet. some hanging rpms in the 1100-1500 range when letting go of the throttle in park logged a little cruise going to drive it today to the exhaust shop so going to log some pulls
ford75mmv1.hpl
bbkv2.hpt
1497323653.hpt
last file is what im using as my reference
