I have a swap i put an lq4 into. new to tuning so looking for some pointers/advice or good starting point or someone to tell me im doin it wrong. started with a '04 6.0 0S 7603. i adjusted VE table a bit as well as timing and idle to get it started. poor throttle control off idle figured because of Auto file so segment swapped manual into it. was still having throttle control issues and after some playing around realized it was from the torque/abuse settings. now it will actually drive and rev.
trying to move into airtuning now but have an issue with stalling making it hard to get a clean log. it will rev and return to idle without stalling while not moving but once i get goin and put in the clutch stalls on coast. did russk a couple times...matched idle spark with octane tables to see if the transition was causing it?
from what i gather throttle follower may or may not help?...i didnt have clutch switch or vss to pcm at first so wired those up. started playing with decay times but dont wanna be d!cking with all that if thats not the direction i need to go.
Here is one of the only logs i actually remembered to hit save on. may or may not be helpful. let me know what to log
'99 lq4
p59 DBW
SBE
706 heads
ls1 intake
stock lq4 injectors
Elgin E1840P cam
t56 trans
AEM 30- WB
thanks
neutralrevsd.hpl subaradospeeddensity4.hpt testidle.hpl sd.Channels.xml
